Thread: clutch problem?
    Regular Member darko2301's Avatar
    Croatia
    Default clutch problem?
    well, i have the 150 1.9cdti engine in my veccy. it has done about 80000km until now (50k miles roughly) and that isn't that much imo. today i experienced very unpleasant thing while overtaking.
    i stretched it a bit in second gear until 4,5k rpm and then shifted into 3rd gear. naturally, rpm were about at 3k at that moment. when i pressed accelerator pedal rpm just jumped rapidly while car wasn't accelerating, like if i was holding clutch and pressing accelerator, and it didnt accelerate!
    i've tried to shift into 4th and then back 3rd and it did the same thing, after pressing the pedal revs just flew into red area without and change in speed..
    luckily a big truck wasnt heading towards me while i was (trying) overtaking, it could end really bad
    so, does the clutch need replacing or what could it be?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Sounds like a slipping clutch to me.
    Today I've noticed that my V6CDTi makes some sort of judder when setting off. It does that only from a standstill. No judders between gearchanges. I guess the clutch is on its way out as is the flywheel.
    Croatia
    it might be it, i'll have to ask my mechanic..
    any other thoughts about this one? really noone knows what could it be?
    Regular Member pscocoa's Avatar
    Oct 2007
    Sandhurst Berkshire
    It will be the dmf and clutch - you have to inspect both - you may get away with clutch but at that mileage worth chaining the dmf if you can get one at a reasonable price
    EVERYWHERE
    Quote Originally Posted by Celes View Post
    The DMF will eventually take the clutch out if it's knackered.
    But in another thread you say that you have 'fuelling issues',and what you describe above does very much sound like the HP pump packing in.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by diesel dog View Post
    Let's hope it's not the HP pump. If it is I might as well put a p-box on to kill it the quick way
  1. Clutch problem
    By shayom in forum Engine & Drivetrain
    Last Post: 10th May 2012, 23:34
  2. clutch problem please help
    By v33tra in forum Engine & Drivetrain
    Last Post: 12th November 2011, 02:09
  3. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  4. Clutch Problem
    By ickleric in forum Engine & Drivetrain
    Last Post: 31st January 2011, 19:19
  5. Clutch Problem
    By Aimee in forum Engine & Drivetrain
    Last Post: 30th August 2006, 23:31
