Thread: Aargh! Gps aeriel still messing up!
    VIP-Member MCD's Avatar
    NE Manchester
    30 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default Aargh! Gps aeriel still messing up!
    Just can't work this out now! It was being dodgy again after work! So I relocated it to the rear window top middle pretty much right next to the point where oe ones go!
    It came on straight away! Drove home. Called into B&Q. When I came back to car about 15min later, started up, nav intialising them wam, gps came on all fine! Thought yeh sussessed it!
    Came home did some jobs, nipped back to car maybe 30min later...came on all fine!
    Just been out now... Some 3 hours later! Just wouldn't come on! Went to boot opened it.... It came on?? (The gps signal I mean! The headunit working fine)
    Can't understand this....should it be outside the car or summit? It worked in last owners car fine... In the inner wing! And it worked fine in my inner wing for two days too! It also works fine if not been turned off for a while!!
    Is there something I'm missing? Could I have messed the cd install up cause I've had the headunit out trying to fit this denison link?
    Knowing my dam luck the headunits gone faulty! Aargh!
    Thinking while I type, do you need to drive the car around a bit to get a signal if its been switched off for a while?
    Mike
    Noobtune 220bhp / 270lb - (07) 2.0 turbo SRi XP1 NAV - SUNROOF/AFL/CD70/XP2'd
    NE Manchester
    30 Post(s)
    Engine : z20net
    Mileage : 80k
    By the way the dension isn't in the car anymore! ****** aerial connection on that was dodgy too!
    Mike
    NE Manchester
    30 Post(s)
    Engine : z20net
    Mileage : 80k
    Silly question!
    Those of you with magnetic ones, which way up you got it? Magnet up or down? Should that make a difference?
    Also mine has a foil back on it over the magnet... Is that necessary? Mines pealing in corner slightly?
    Do you have web links to what aerials you have please?
    So for so many questions... Just a bit ratted, bit of a brain dump going on!
    Surely this should be fun and easy?
    Mike
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    I had the nav aerial stuck next to the alarm speaker in the boot on the ns, just below the fuse box.
    It worked fine in my car 100% so why yours is playing up I don't know?
    Unless that aerial lead now has a fracture?
    May 2008
    Bucks
    Quote Originally Posted by MCD View Post
    Mike
    http://cgi.ebay.co.uk/SAT-NAV-GPS-AN...1%7C240%3A1318
    Can't see it would have gone faulty, but just incase.
  1. Aeriel HELP!
    By 1.9Cdti Elite in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2009, 11:17
  2. Aeriel HELP!
    Last Post: 1st November 2009, 10:55
  3. dealers aargh!!
    By stusdc in forum General Chat
    Last Post: 22nd June 2009, 10:41
  4. aargh my ears
    By Morephun in forum The 'Off Topic' room
    Last Post: 11th February 2009, 17:49
  5. aargh those pesky wipers lol
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2008, 11:30
