Thread: Anyone used air intake cleaner in the 1.9CDTi?
    May 2006
    scotland
    confused Anyone used air intake cleaner in the 1.9CDTi?
    All, given the problems with EGR etc on these intakes, has anyone ever tried squirting carb cleaner or the likes into the air system of their Diesels on a monthly basis to try and combat the build up. This is the first time I have had a turbocharged car and I wouldnt have a clue on where to do this (it was simple in a normally aspirated car). Additionally, would you do this with or without engine running? Any views, help would be appreciated.
    Regular Member silverhairedracer's Avatar
    ESSEX
    Use millars 4 or somthing similar And you do not get the soot build up !,
    May 2006
    scotland
    Thanks for that. I do use millers 4 in the fuel but I wonder if the engines would benefit from a cleaning agent right at the air intake.
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Quote Originally Posted by silverhairedracer View Post
    where can i get some of this? will it keep the EGR valve looking like new, as you say the soot doesnt build up?? cheers, mick.
    ESSEX
    You can get it at most "decent" motor factors,it certainly worked for me when I stripped the EGR it was clean !,the main problem with the valve is the solonoid its self that sticks which is one of those things that you cannot avoid.
    May 2006
    scotland
    I take your point about millers and in your experience, your EGR valve was ok. I just wondered if anyone on this forum has used any intake cleaner and if so, how was it administered.
    I would hazard a guess that it would be best to do it at the point of the air intake at inlet manifold but I am unsure if running the engine (at idle) with the pipe from intercooler to inlet manifold disconnected would cause any spanner lights. Maybe best to be done with engine not running.
    Any views welcome.
    thanks
  1. Wynns Diesel EGR3 Air Intake & EGR System Cleaner
    By Gazz in forum Engine & Drivetrain
    Last Post: 11th October 2012, 07:46
  2. Replies: 1
    Last Post: 15th September 2012, 21:13
  3. Wynn carb & intake cleaner for 1.9Cdti 150
    By amand in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2012, 20:16
  4. air intake cleaner....which one please cdti
    By hairy31 in forum Diesel Engine related
    Last Post: 30th March 2012, 23:00
  5. Forte diesel intake cleaner
    By DeJohnny in forum General Motoring Chat
    Last Post: 3rd March 2012, 11:27
