Results 1 to 2 of 2
Thread: Connecting my Cigarette lighter
    Apr 2009
    galashiels
    Default Connecting my Cigarette lighter
    I have a compete cigartette unit with three connector plates (thin flat metal) Inside the hole in the car where it goes is a two wires connected to a small white thin female clip. What do I need to connect the two? Another cable? Where can I view this and buy it in line? Can someone please advise me?
    Graham
    PS Im needing it to connect and charge my satnav.
    Vectra Energy 04
    Regular Member Zark's Avatar
    Herts
    i think you're ciggy lighter should have a live feed, a negative and a feed to the bulb (live when the lights are on)
    if you can get hold of a circuit tester (or a couple of crocodile clips and a bulb!) you can probably quite easily find a suitable wire down there. The only bit you'll need to decide is whether to have a permanent (always live) live or whether you want a live that's only on with the key in... Personal preference really, but you should be able to find a suitable wire either from near the cigarette lighter or from the rear of the stereo... HTH!
  1. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  2. cigarette lighter help
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2010, 21:47
  3. Re: Cigarette Lighter
    By ope126 in forum Styling
    Last Post: 19th December 2006, 22:32
  4. Cigarette Lighter
    By philjs in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2006, 22:19
