Thread: Can I replace HU as DIY novice?
    Regular Member Markyboy72's Avatar
    Gloucester
    Default Can I replace HU as DIY novice?
    Guys (& Gals?),
    I have a 2007 Facelift Vectra CDTI SRI and love some of the replacement headunits that I've seen on here. I want to spend around £500 to replace my CD30.
    Would welcome some help from you experts; I will buy a facia in the right colour, have picked up I need that. I also know that I need leads to ensure my Kenwood/Pioneer unit can still be operated by the steering wheel controls and the tool to remove existing stereo.
    However, how easy it is to remove and instal a new unit as a complete novice?
    I am not an idiot , but have not done anything like this before - are there any websites/threads with step by step instructions for me to follow?
    Finally, can anyone give me a complete list of ALL the extra stuff I need to buy (other than the headunit model, which is still to be decided) in order to instal and ensure that the steering wheel controls work too?
    Really finally, I will also be installing bluetooth handfree kit (want it to be part of the headunit I buy) and if I need any extra cables to make this happen, please tell me?
    I look forward to your helpful comments.
    WGAF#5
    you will be able to buy the necessary leads to convert standard input to make/model selected and a SOT lead (sound on top lead) for the parrot kit with a feed off of the bottom of the cigar lighter- if you go for a single din you will also need a facia adaptor - very easy to do youself and the money you save (probably between 60-80 quid) can go to the cost of the head unit/carkit
    hth regards
    Dez
    Regular Member n30jjb's Avatar
    Barnsley
    Quote Originally Posted by Markyboy72 View Post
    Guys (& Gals?),
    A lot of the new Pioneer and kenwood units have the bluetooth biult in nowadays. This would make life a lot easier and possibly cheaper for you. I've got a kenwood bluetooth unit and it's brill, the quality of the phone calls is awesome.....
    As for the fitting if you go for one of these units it is as simple as 1 2 3.
    1. Remove the old unit using some keys, available from your dealer and local motor store
    2. Fit the fascia adaptor in place.
    3. Plug in and fit the new stereo in place.
    Dead easy............
    If i can do it. SO CAN YOU!
    Wales, UK
    Definatley do it yourself, quite easy and enjoyable I think !!
    Youc an be proud of yourself then lol :-)
    Barnsley
    This pioneer unit seems very popular. And available for less than £300.00 it's a bargain. Bluetooth and Ipod ready.
    http://www.pioneer.co.uk/uk/products...0BT/index.html
    Dublin
    Sorry to hijack the thread with a slightly off-topic question:
    When replacing the factory HU with an after-market one, is it necessary/advisable to disconnect the battery? Also, can the job be done without removing the glove box or is this also necesary? (I plan to fit a steering control adapter on a Pioneer HU)
    Sunny Dartmoor
    No need to disconnect battery just turn off ignition,hth.......
    Surrey
    I never disconect the battery.
    Getting the wires behind the radio can be a pain but no real need to remove the glove box. FYI the glovebox only has about 5 torx bolts so takes 30 seconds to remove and pulling the wires behind becomes easier.
    Dublin
    Thanks for the replies guys.
    Anyone know what size torx screws hold the glove box in? I bought a t25 screwdriver but looks to be fractionally too big.
    Surrey
    T20
  1. help for a novice
    By starykokot in forum Petrol Engine related
    Last Post: 12th January 2011, 23:01
  2. detailing novice
    By Griffonman in forum Detailing and Car Care Discussion
    Last Post: 12th June 2010, 21:34
  3. Novice in Need
    By FosterBoss in forum Engine & Drivetrain
    Last Post: 8th May 2009, 20:19
  4. Novice....need a little assistance
    By johnsonr380 in forum Engine & Drivetrain
    Last Post: 22nd April 2009, 20:48
  5. Getting the car looking good ( novice )
    By gaz4d in forum Detailing and Car Care Discussion
    Last Post: 16th February 2009, 10:29
