Results 1 to 10 of 19
Thread: why is easy start addictive
    Nov 2007
    lancashire
    Default why is easy start addictive
    why is easy start addictive, i have my own theories on this but would like to know the REAL reason for it???????
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Dunno about people, but at college i was told because it caused accelerated bore wear (detonation/bore wash) over time compression was lost and as diesels need a higher compression starting help was needed more and more,hence the addiction.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    If you use it too often the engine (normally diesels) may end up relying on it more and more??
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by tyreman View Post
    Quote Originally Posted by Big-Pete View Post
    That's correct guys.
    We could always tell if someone was trying to start a machine in the yard using easy start.... the smell gave it away.
    Nov 2007
    lancashire
    well the theory i got was because easy start combusts with a big bang it compresses conrods a smidge every time you use it, leading to lower compression and the need to use easy start for the next start up.
    come on boys sombody knows the real reason!!
    Ashington, Northumberland
    Tyreman is correct. It drys the walls of the cylinders leading to wear (immediately on use I might add), all lubricant is stripped from the bore. continued use will perpetuate this process leading to bore taper and ovality. This can lead to bore wash, then you're in trouble. Some people reckon putting a new set of injectors in will cure it. If it has been used for prolonged periods, then no, it won't. A re-bore and new injectors will, but how much is that gonna set you back Simple answer is, if your diesel is hard to start, find out why and put it right.
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    whats easy start?
    Regular Member 30ltr nutter's Avatar
    dunstable
    it usually brakes the rings so u loose compression so causes starting fault so thats why they say its addictive cause u need to use it all the time a start pilot works the same way but it releases such a small quantity that it does not do the damage the damage is usually caused by the finger on the trigger to long
    It's an ether based spray that is MEGA inflammable. You spray it into the air intake to 'persuade' an engine to start. Ferocious stuff that I avoid if I can help it. If an engine started ok before and now its hard to start, then theres a reason. it never needed easy start before so it shouldn't need it now
    Full Member gibbon7000's Avatar
    lincs
    Quote Originally Posted by aerodynamic18 View Post
    whats easy start?
    My other car. 1972 1641cc slammed beetle. On the road finally!!
  1. Easy MODs about to start
    By robdd1 in forum Styling
    Last Post: 4th August 2011, 16:39
  2. Brilliant but addictive!
    By Taffyopel in forum Comedy & Humour
    Last Post: 22nd September 2009, 10:10
  3. Annoying but so addictive
    By AJA in forum Comedy & Humour
    Last Post: 12th October 2007, 18:15
  4. VXR game....very addictive
    By Big Davie in forum Comedy & Humour
    Last Post: 14th January 2007, 00:06
  5. ery this its addictive
    By STAV in forum Comedy & Humour
    Last Post: 12th January 2007, 18:06
