Thread: Diagnostics Questions?
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Default Diagnostics Questions?
    does anybody know where the diagnostic plug is on a Vectra 04 2.0l DTI est?
    and
    where can can i get a code reader at a reasonable price?
    i have had the car on the diagnostics twice in the last week and at £30 a time i would rather pay for my own machine, then i can do other peoples aswell.
    cheers, mick.
    Sunny Dartmoor
    Should be under the ashtray,like very other vectra/signum.........
    Try ebay for a code reader........
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    ok, cheers.
    i have just been and picked up the car from the garage, and the faultcode P0400 has been stored twice with two different descriptions of faults, these are:-
    P0400-exhaust gas recirculation system amount insufficient.
    P0400-exhaust gas recirculation solenoid valve signal improbable.
    has anyone elce had these fault codes and what did you do to fix them?
    i have ordered a new EGR valve, will this fix the faults?? cheers, mick.
    Winteringham
    yes it is a fault with your EGR had it on mine the other month new EGR fitted working great now
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    As Gregc stated, a replacement EGR should fix all your problems.
    TBH, Its really a very simple job to remove it and give it a good clean, plenty of HOW-2's on here showing how to do it.
    I just gave it a good soaking in a carb cleaner, and using a stiffish brush and plenty of cotton buds, clean all the crap from around the 2 circular valves, one in each aperture. Also, make sure you clean out as much crap as possible from inside where it bolts on, as the sooty deposits really build up quite a lot inside there, you need to do this anyway even when fitting a new EGR.
    Make sure you dont drop the aluminum gasket when removing it. Probably wise to replace both gaskets, but I re-used mine and all seemed okay.
    It's surprising how the pickup performance falls off due to a partly blocked EGR even well before it puts up a fault code.
    Even after just 12 to 15k after fitting a new EGR I noticed that my old Vec-c was lacking that fast pickup oooph when you hit the accerator, but a couple of hours or less spent cleaning it resulted in that fast pickup returning again.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    changed the EGR today and all is well!!!
    no spanner light and much better pick up from 1500RPM.
    cheers for all the help and advice everyone gave me. keep it up.
    mick
  1. Diagnostics
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 03:08
  2. Diagnostics
    By neill in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 10th April 2012, 19:55
  3. been to vx for diagnostics :(
    By andy76 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th March 2011, 20:33
  4. VW Diagnostics
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 29th April 2009, 09:33
