Results 1 to 10 of 27
Thread: air con
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    Default air con
    hi guys.. little problem..air con not blowing as cold as it should..do i take it to my local helpfull garage for re gas or to main dealer as car still under VX warranty i know the re gas isnt covered by warranty the compressor is kicking in like it should ....thanks in advance guys
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I would take it to kwickfit they do it for £45 iirc and if they cant get it a certain % colder than it was before then they dont charge
    Regular Member Ben999's Avatar
    Milton keynes
    I topped mine up with the stuff from halfrauds, was about £16 did the job perfectly. (still works 2 years later)
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    might be able to get you a number of some one local tony
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved to troubleshooting
    Regular Member pauls898's Avatar
    Malvern
    Put my air con on for the first time today for a while, no change in temperature at all, pipes in engine bay not cold at all I suppect the coolent has leaked out?
    Shall take round to VX
    PS
    How does these Hafford DIY kits work? I thought the air con was under high pressure?
    11 Post(s)
    Don't bother with the DIY aircon kits. For the same price that you would pay for a miracle can that won't pressure test or leak test the system, you could get it looked at by someone with an all singing and dancing machine.
    Kwikfit for example charge something like £40 to £45. If your AC has a leak then they won't charge you a penny. Meanwhile the DIY kit has left you out of pocket and not told you that your system might have a leak.
    That aside, it's best to use the AC weekly for 10 mins or so (even in winter) as it also contains oil that lubricates the system as well as stopping the rubber seals from drying out.
    Malvern
    Thanks Dave for the heads up
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The DIY kits do work, but won't find a leak. If it is not working due to general lack of use, that will be rectified by a top up, then they are fine and easy to use.
    You just connect the pressurised can to the fill point and spray away....
    11 Post(s)
    Quote Originally Posted by Ste View Post
    The DIY kits do work, but won't find a leak. ....
    But for the price of them, you might as well pay someone else to do the job.
    Unless the seals have dried out/perished through the lack of general use, and the DIY top up will only last a short time.
