Results 1 to 10 of 11
Thread: spanner light
    braintree
    Default spanner light
    hi to all started my signum up started miss firing then the spanner light came on and the car died took the key out and tried again and all seems fine has anyone else had this? any ideas?? is it a dealer jobby cheers for any ideas
    Keep your eye on it
    Record the date and mileage when it happened, also take a digital photo of the dashboard (as you can present this as evidence at a dealership)
    If it happens again, then repeat
    If it happens a third time, then book the car in
    By this stage there should be a fault logged on the EMS
    braintree
    cheers will do
    braintree
    just took my siggy to the dealers and its the petrol pump again 4th one had the last one in jan 09 tried charging me for test to find out the problem then after they agread to forget the 30 od pounds got a phone call saying my front and back brake pads need replacing on have 5% on the front and 15% on the back but last monday had a mot and was told only 45-50% worn over all told them to leave it should i report them or just keep quiet ?
    Why is the dealership looking at the brakes, if it is NOT booked in for that...
    Oh that's right, they need to make it look like they actually had an interest
    Personally, I would look for another dealership, even if it costs you a little in travelling to/from them
    My nearest one is Stirling, but I travel to one I have more faith in as I have used them for 12 years now
    Mileage : 000
    Ask them why they came to that conclusion. When the MOT station gave you the figures they did.
    braintree
    ive asked them to print it all out for me to have proof
    They must have very good calipers to give a reading of 5% material left!
    Assuming the front brake pads have 10mm of material, that means there is curently only 0.5mm left
    However, the MoT tester says there is 4.5mm
    That is some difference!
    Equally, I was under the impression that all Vectra C were now fitted with front brake pad sensor warnings, and they tend to go at about 2.0mm of tread
    I think that dealership needs a nudge to wake them up
    braintree
    is that the same for signums
    Yes, the signums as a rule are better spec'd
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
