Thread: B&Q hose attachment warning
    Jun 2007
    Black Country
    Default B&Q hose attachment warning
    I decided to swap my old and worn plastic HOSELOCK connectors for the Brass type that are B&Q's own brand, nice and shiny, look a lot better and wont fade in the sunlight
    BIG MISTAKE
    I bought a pressure washer this morning, and to try it out I washed the car. I connected the B&Q attachment onto the pressure washer, turned the water on, and look what it did to the pressure washer fitting
    Luckily, as my old pressure washer was dead, I had the old fitting and swapped it onto the new washer. Ive replace the naff B&Q fittings with the old and worn HOSELOCK parts, and they work fine.
    Feb 2007
    North west
    You should use brass with brass - both ends need to be the same. You can get all the various bits in brass if it takes your fancy...
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Ah... you have found out the plastic and brass connectors dont interchange as well then.
    I found out like you, when I did the same when connecting up water hoses to the caravan sites mains water when we first had our caravan. (sold it a while ago now) I too would have thought they would fit okay, but it seems not.
    Plastic to Plastic or brass to brass but not mixed it seems.
    Jun 2007
    Black Country
    Yeah I wasnt very happy to say the least
    they never made a good enough water tight seal either
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    only combo would work would be a brass 'male' fitting into a plastic 'female' fitting
    Jun 2007
    Black Country
    sounds a bit kinky to me
    Aug 2007
    Lisburn, N.Ireland
    Apr 2008
    In UK
    Quote Originally Posted by Guyver1 View Post
    No they dont, and as you found, they ****** up the plastic fittings too, I must admit, I never knew there was any difference either, I bought the brass bits thinking they would be better quality and last longer.
    We all live n learn.
    Jun 2007
    Black Country
    Quote Originally Posted by Cameron43 View Post
    A mate told me that the ball bearings can fall out if the frost gets near them aswell, not good for the price they cost
  1. sticky PAD (Parrot Attachment Device) help needed
    By dlp in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2011, 22:32
  2. attachment test
    By xnetco in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2008, 23:11
  3. New bits ready for attachment
    By Leviathan in forum Styling
    Last Post: 1st July 2008, 21:14
  4. rear towing eye attachment missing!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 22:04
