Thread: Fault code B3901
    Regular Member Harry's Avatar
    Uxbridge, London
    Default Fault code B3901
    Could anyone be so kind as to enlighten what fault code B3901 refers to?!?! Apparently it's to do with the "body control module".
    Does anyone know what this is and why it would send my car into limp home mode as i was accelerating from 50 mph in fifth gear onto a dual carriageway?
    thanks
    Uxbridge, London
    doesn't anyone know where i can find a description of this fault code?
    Feb 2006
    Dorset
    It runs between sturminster newton and shaftsbury , nice road ..........
    South East
    How did you come by this code, if V/X gave it to you via tech 2 ask them. I was not aware that you could decode the ECU yourself, if so please enlighten.
    Jan 2006
    Dalriada
    the garage i bought my car from were not very keen to give out the details of what the fault codes were
    Even give the local garage a ring Harry and they shoud be able to tell you if they arent strange like the one i USED to deal with
    Uxbridge, London
    Quote Originally Posted by vectrasri03
    Don't worry...i'm not decoding the ECU myself, i took the car into the dealer because the car went into limp home mode but reset itself when i next started the car, but i wanted to see if a fault was logged which it was and the dealer reset the ECU. I had to prod them for an answer as to whether the fault was logged and then again to give the fault which they eventually did, saying it was B3901 which related to the Body Control Module.
    Quote Originally Posted by gil16e
    mine didn't volunteer the info either, it's only after i asked the guy outright what the code was and what it related to did he go into the workshop and tell me. it's probably just a random code that he's picked off the top of his head.
    i think i'm going to ring the dealer and ask to explain. why shouldn't they offer an explanation???
    Melbourne, Australia
    How does Wrong Environment Identifier Received sound?
    * The control unit receives a wrong Environment Identifier.
    Effect:
    * The current message and all following messages within 60s will be ignored.
    Don't ask me what this means though...
    Uxbridge, London
    So what does that mean then Steve?
    No seriously, does anyone have a clue?? That's just gibberish to me.
    But thanks for finding out for me though.
    Sweden
    Not much but ..... :
    Body Control Module The BCM controls much of the driver's interface with the vehicle. In many cars it operates the headlights and turn signals, and drives the speedometer and tachometer displays. Normally located either under the dash or under the hood attached to the firewall.
  1. Fault Code Help
    By rmg1 in forum Y & Z30DT Specific
    Last Post: 3rd October 2012, 21:12
  2. fault code on vec c 1.8 sri please help
    By gavs-sri in forum Engine & Drivetrain
    Last Post: 10th April 2012, 21:52
  3. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
  4. Help with fault code,
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 21:57
  5. Fault Code
    By fattony in forum Engine & Drivetrain
    Last Post: 6th April 2009, 22:24
b3901
b3901 vectra c
b3901 opel
