Results 1 to 2 of 2
Thread: Diagnosis needed
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Default Diagnosis needed
    Diagnosis needed before talking to main stealer.
    There is a constant rubbing droning noise from the front drivers side wheel.
    Jacked it up this morning and there is some slight play in the wheel compared to the others.....so wheel bearing? or tie rod?
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Tie rod should not give off a droning noise even if badly worn. Sounds like wheel bearing i'm afraid, though it could be something else. I had a metallic rubbing noise on my Signum, it turned out to be the little metal plate at the back of the brake disc had been disturbed and was rubbing on the disc. Worthwhile checkiing it out.
    3.2 v6 Signum and loving it
  1. diagnosis time
    By roverjay in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 12:05
  2. Swirl Bar Actuator: Diagnosis Needed!
    By barkzz in forum Engine & Drivetrain
    Last Post: 4th October 2009, 17:57
  3. Engine Diagnosis
    By stevej in forum Troubleshooting
    Last Post: 14th August 2009, 10:46
  4. Fault Diagnosis
    By jamesworts in forum Troubleshooting
    Last Post: 6th August 2009, 21:36
  5. VX mis-diagnosis!!!!
    By Woodsta in forum Engine & Drivetrain
    Last Post: 8th February 2007, 22:39
