Thread: Wheel Bolts
    Plymouth
    Default Wheel Bolts
    Hi Guys n Girls.
    Just went to paint my rear calipers and the ****** locking nuts wont come off.... the wheel brace just keeps slipping off then the locking nut slips off..
    The only way i got the front ones off last time was with a 4ft Scaffolding pole on the end of the brace and my old man holding the brace square to the nut...
    So looking at getting another set of locking nuts....
    What do you think to these....
    https://www.halfords.com/webapp/wcs/...7184&width=800
    and yes i will be paying the £5 for halfords to remove my olds ones!!!
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    think they are ok had them on my old vec but luckily enough for me once i put them on i never had to take them off again
    Regular Member barkzz's Avatar
    The locking nuts are a complete pain in the ass!
    Apparently the locking not should only be tightened by hand, and not torxed like the standard nuts. I got two of mine stuck on the front wheels, and snapped the locking nut in the process of removal. So i ordered another locking nut from VX, which cost about £35.
    It was cheap ****, and snapped on the first turn. Had to get a bloke with a titanium socket set to get them off. Think he used 18mm barrell piece, but be warned its likely to cause damage to your alloys. He had to belt the **** out of it to get it to grip on.
    Other than that you would need the lockin nuts drilled out, which is about £65 per corner, and again can cause damage to the alloy.
    Once i did eventually have mine removed, they got thrown in the bin, never to be used again! Learn by your mistakes so to speak!
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    i had the same problem. its garages cutting corners and using a windy wrench to do the job. just take the car to your vaux garage and they should get them off for free with a windy wrench again. but they "only ever use a tourqe wrnch to put them on" lol. the vauxhall ones are usless, even the bloke said to go get some aftermarket ones as the vaux ones just round off so easily or this happens.they did mine for free and i just put normal nuts back in.its got to be a special kind of person that wants to steal a set of 16 inch standard vauxhall alloys!!!
    then again you never know!!sods law states ill go outside and itll be on bricks tommorow
    Sunny Dartmoor
    You should've given me a shout Dan,could've sorted it for you,if you need anymore help just give us a shout.......
    Plymouth
    Quote Originally Posted by glenboy View Post
    Still havnt got them off yet mate!
    Went to halfrauds to pick up those bolts i posted in the OP but all they had was the £35 ones...
    They told me i had to reserver them online to get them at £15... so i went online on my phone got as far as viewing the bolts then my phones bat died!!!
    And no.... they still wouldnt do them for their online price!!! GRRRRRR
    Im hoping to pay them the £5 to put them on... hopefully they will have more luck.... otherwise its off to a tyre shop so they can gun them off as they norm have no probs!!!
    Quote Originally Posted by Diet1985 View Post
    Be warned, i tried to get mine gunned off at a garage, and even they couldnt succeed.
    Went to another garage and they wouldnt even touch it, for fear of shearing the locking nut!
    All this thanks to the pillock who torxed the locking nuts.
    What made me fume even more was the fact that i needed them off to do a tyre rotation!
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i always do mine hand tight them a final turn with a ratchet.....if you have damaged the key then vaux can get you another for £25 as long as you have the key number.
    Newcastle under Lyme
    I always request grease to be smeared on teh bolts before fitting now. Little trick I learnt from a mechanic. F1 Autocentres didnt seem too happy at first but obliged after asking each other
  1. wheel bolts
    By john-d in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 23:06
  2. Spare Wheel Bolts From Locking Wheel Bolts
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2007, 16:55
