Results 1 to 3 of 3
Thread: Fault code P1482
    May 2008
    Tyneside
    Default Fault code P1482
    I have fault code P1482 "Cooling fan speed output circuit" stored on my engine management system. Anyone with any ideas what to check for or items need replacing?
    Mar 2007
    Sheffield
    bumpety
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    I have had this fault code intermittantly, it has been suggested that it may be a fault with cooling fan module , since my fan seems to be working correctly. There are a number of connections you can check and clean. This didn't work on mine, although it is rearing its ugly head less often. Failing that replace module. I haven't done this as it doesn't seem to cause any problems, just code. If your car isn't overheating, i wouldn't worry.
    this thread has pictures of module and some ideas.
  1. Code P1481-P1482-P1483
    By Aikon58 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2013, 12:30
  2. 3.2 fault code 10-3
    By ip8645 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 21:33
  3. fault code
    By mvl41183 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2012, 10:00
  4. Error CODE P1482
    By Bikedylan in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2011, 11:16
  5. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
vauxhall fault code p1482
vectra c p1482
username and password for p-1482--Vehicle Management System project
vauxhall insignia 1482 fault code
vauxhall vectra c fault code p1482
p1482-02 opel
p1482 opel vectra
