Thread: Unsure what axle weight sprins to order, need help
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    Default Unsure what axle weight sprins to order, need help
    Hi all,
    I am on the verge of ordering my Eibachs from LMF, only thing Im unsure of is axle weights...
    Shows the following on the door plate.
    1 1065
    2 0980
    Just for info its a 2002 plate GSI 3.2
    I was planning to order the 1061kg to 1130kg kit, would this make the front end lower at all? Due to the upper limit of the spring being higher than the axle weight?
    The next drop down is 966kg to 1060kg but would the opposite apply to this? Spring being rated lower so the front of the car would be too low?
    Any help would be appreciated.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    If you tell steve what the two above numbers are he will be able to supply the correct springs for you car, thats all he asked when i ordered some from LMF.
    Hope that helps?
    Milton Keynes
    Ok fair enough, thanks for that.
    Has anyone else fitted these to a GSI on standard shocks? can you give any indication of ride height?
    Pictures would be great.
    Milton Keynes
    Anyone?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    what is the drop on the eibach's....as with you having sport's susspension already it will be 15mm lower than ordinary set up....
    Midlands Mod Shop - NFFC.
    Regular Member big O's Avatar
    Good old Sunny Scunny!!!!
    With eibachs it's not so much the drop it's the handling that's improved, they do make a massive change, but if you want a big drop go for PI springs.
    Milton Keynes
    Thanks for the replies.
    I know it will drop it 15mm but its nice to see some pics to get a idea.
    I dont want to go too low because i live in Milton Keynes and you find lots of speed bumps round here. I think the Eibachs will be perfect for me.
    Shocks may need doing as well. if i take a tight-ish corner hard (like going round a roundabout) it feels like the back end wants to come out. never had that on a front wheel drive car before. all other cars ive had the front gives before the rear.
  1. 2.8T V6 Axle Weight
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 10:23
  2. axle weight
    By chelskilee in forum Handling & Braking
    Last Post: 23rd February 2009, 20:53
  3. Front axle weight
    By LOCKSTOCK in forum Suspension, Wheels & Brakes
    Last Post: 19th September 2008, 21:33
  4. Axle weight?
    By Paul_O in forum Suspension, Wheels & Brakes
    Last Post: 13th August 2008, 17:53
  5. axle weight ?
    By JOE DTI in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2006, 17:41
