Results 1 to 10 of 14
Thread: Sticking Electric Mirrors
    Oct 2007
    airdrie
    Question Sticking Electric Mirrors
    Hi I have a 2004 '54' plate Signum 2.0 Dti Elite with sticking electric mirrors. Both mirrors move left, right and down but not up! Additionally the electric windows sometimes are temperamental. If up the button needs to pressed for up and then down before it brings the window down and the same in reverse. I do not know if the faults are connected in any way. Any ideas?
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    As a process of elimination, have you tried another switch pack? Shouldnt be too expensive off the bay???
    Oct 2007
    airdrie
    Thanks for the reply. Just discovered it today after getting car back after my wife used it and moved the mirrors!
    I take it if searching on bay then it is called a switch pack.
    Birmingham
    Quote Originally Posted by yesbutno View Post
    Dont know mate, thats a good Q! TBH, your probably better off searching for Vectra c Electric window....will throw up all the related hits!
    Birmingham
    I just done a quick search and the only ones on there are the passenger side. Also search for vectra-c breaking, should be loads on there pal.
    Also, put a wanted add in the wanted section on here, someone is bound to have one knocking about! HTH!
    Oct 2007
    airdrie
    Thanks, I had a look, I will give it a go over next few days, in the meantime any other ideas/suggestions are welcome.
    Regular Member gibbon7000's Avatar
    lincs
    I would say the same a vaux man G, Have you tried www.megavaux.co.uk in Notts
    Oct 2007
    airdrie
    Thanks, I have sent a parts request to megavaux!
    Birmingham
    Hey mate, did you get your switch thing? If not, there is one on the bay, chepa start...HERE YOU GO!
    Only thing I dont know is if your's is 4 x Elecy Windows or just front!
    HTH!
    Oct 2006
    Wellingborough
    worth spraying some contact cleaner into your switch before you replace it
  1. Electric mirrors
    By ZWoodyz in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2012, 15:13
  2. Electric mirrors.
    By stanian in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2010, 23:36
  3. Electric mirrors
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2010, 19:25
  4. Electric side mirrors sticking
    By bonneyboy in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2008, 12:42
  5. Electric window sticking..
    By Paulmac07 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2006, 00:04
