Thread: Tyre pressure
    Regular Member jun's Avatar
    burton-on-trent
    confused Tyre pressure
    Im going for nice long drive to lands end monday and want to give me car a once over before going. And wondered whats the correct psi for my tyres they are 235/45 /17.
    cheers guys.
    Regular Member fredfox_uk's Avatar
    Northants
    Rule of thumb I've always used is double the wheel size and +2 so I use 36 on mine.
    Regular Member Ben999's Avatar
    Milton keynes
    according to the manual 32, but I do usually go for the double +2 option.
    Quote Originally Posted by fredfox_uk View Post
    Quote Originally Posted by Ben999 View Post
    Easy to remember, always worth a check when you stop for a break to see how they are doing hth ..........
    Regular Member RhayaderSax's Avatar
    Rhayader
    Look in the manual. The double plus two is a good rule of thumb if you're topping up a "squidgy" on an unfamiliar car but remember stuff like the fronts on a diesel will typically be higher psi to compensate for the heavy lump under the bonnet.
    Saying that I pump mine up to what the manual says & it feels too hard when driving. Every rabbit poo in the road feels like I've run over an elephant. Book minus 2 psi works for me (and I do a lot of driving on twisty roads) although even the first time I read the book figures for the 3.0 diesel they seemed a bit on the high side.
    Full Member gibbon7000's Avatar
    lincs
    As i found out a couple of weeks ago when i asked the same question, double the wheel size +2. hth
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    burton-on-trent
    Thanks for the help guys.
    Plymouth
    i wa surprised that when i looked in my manual it told me 34 for the fronts and 46 for the rears!! for long drives fully loaded!
    When u pass over the Tamar Bridge entering cornwall look left and u may spot me
    Belfast
    235/45? Wrong size of tyres. 225/45 or 215/50.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by _ZS_ View Post
    yes they are.. but then they are actually the same size as if you used 215/55 16"
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. what tyre pressure??????
    By dannyjpuk in forum General Chat
    Last Post: 6th March 2010, 21:27
  3. tyre pressure
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 10:30
  4. tyre pressure for GSI
    By effone in forum Handling & Braking
    Last Post: 7th December 2008, 06:07
  5. Tyre pressure
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 18:41
