Thread: rear brakes
    greenock
    Default rear brakes
    right was driving the car today and a grinding noise appeared from rear passenger wheel
    basically sounds like there is no pad left
    so i am assuming the disk is knackered as well
    now shouldnt the pads wear at the same rate?
    are disks and pads covered by the network q extended warranty?
    the car is a 57 plate cdti sri?
    Edinburgh
    check the pad, it could just be it's getting low, some pads have a bit on them that makes a noise to let you know they are getting low. you'll only need a disc if you can see a groove in them or they are lipped.
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Not sure about the warranty, front and rear pads do not wear at the same rate but both rear should.
    Although if you have a dodgy disc it would wear the pads on that side more!
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    Siezed caliper? I had a similar problem a couple of months ago - looked fine from outside, but the inner part of the caliper was siezed and the inner pad was down to metal. New discs, pads and a caliper required.........
    Quote Originally Posted by ryanhamil View Post
    Brakes are covered on my Network Q but you need to check. You may also find it's only the pads why not call them hth ...............
  1. need help for rear brakes
    By sharney2011 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 18:20
  2. rear brakes
    By johnytaff in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2011, 19:33
  3. Rear brakes
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 22:50
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
  5. Rear brakes
    By dan1983 in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 21:09
