Thread: Help ! Signum seat change
    Regular Member Lump's Avatar
    coventry
    Default Help ! Signum seat change
    ok trying to do my seat change, back seats has two bolts at the front. got those out. and then what ? there is no way to se where the other two nuts plugs.
    how do they come out ?
    ps the how to is for a Vectra
    Northampton, UK
    Hi mate, as far as I know, there's 4x bolts/screws at the bottom-front of the seats and 2x Hook type things at the rear. You have to feel your hand down the back to find them.
    To remove your back seats... it should go something like this -
    1.Open the doors.
    2.Undo the bolts at the front.
    3.Pull the seat up, so its sitting loose at the front.
    4.Then push the seat backwards and pull in the direction of the door.
    5.You should be able to unhook it at the back corners nearest the door.
    coventry
    thanks for the pics, not been able to do it. but will try again tomorrow.
    so pull the front up as much as i can. and then try and move the seat outwards towards the door ? right hand pulling ???
    thanks again
    Northampton, UK
    Ok, had another look... I think I showed you the wrong bits!
    Ok, so you've removed the front plastic cover and found the front bolts... Take off the headrests. Now, slide the seat forward on its rails, and then drop the seat like you would to get stuff in the boot. Undo the clips that hold on the seat cover at the back. There should be a backrest part that slides under the boot floor. Pull this out and you will see the other bolts under there. You'll need to undo the belt buckles too. Also be careful of any connections or looms you may have under the seat.
    Any Q's just drop me a PM. I think I've got it right this time! DOH!
    coventry
    ill have another look tomorrow if i get the chance, thanks i may call on you again if required
    Northampton, UK
    Glad you got it sorted mate.
    coventry
    ill do a how to, wont be today though
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    hows it going then lump?
    coventry
    wont be doing it today, got to much paper work to do
  1. Signum Seat
    By makeitfunky in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2010, 22:42
  2. Signum Seat Help :)
    By maurauth in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2010, 21:26
  3. Signum 5th Seat ??
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2009, 23:15
  4. Seat Belt Law Change
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 17th March 2009, 14:19
  5. where to buy seat covers for a signum
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2008, 10:27
