Results 1 to 10 of 13
Thread: antifreeze and distilled water
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    Default antifreeze and distilled water
    as my antifreeze is due for replacement (5 year old) im thinking of refilling with distilled water as it does not bubble when it gets hot like tap water so is better if the engine gets hot,plus it does not cause furring like tap water does,i do not know if vauxhall/opel use it at the factory or if they use tap water ,i know the japanese use distilled water and all japanese motorcycles use it,what are your oppinions on this?
    Regular Member Avenged's Avatar
    Liverpool
    they don't use water.
    they use a premixed solution which you buy from dealers/motor factors mate!
    Regular Member mattolly86's Avatar
    oxfordshire
    all coolant should be filled with distilled water!
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by Avenged View Post
    Strange that; each time I've bought the long life antifreeze from VX you have to mix with water as it didn't come premixed.
    Cheers Pete
    Wales
    I would have thought that any decent mfr would use distilled/de-ionised water - I cant see using plain old tap/ordinary water worth the risk
    slough
    Just had a look in the owners manual on this and it says in there about topping up antifreeze; says ' If no antifreeze is available, top up with clean Tap Water, if Tap Water is unavailable, distilled water can be used' !! you'd think it would be the other way round wouldn't you! mind you I've always used tap water even when changing coolant and never had any problems and I 've done this for years.
    Cheers Pete
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    Never heard of this before 'Distilled Water' April the 1st was a couple of days ago ....
    slough
    How do you mean? do you mean you've never heard of distilled water being used in the coolant before ?
    Cheers Pete
    Cheers Pete
    Nope .........................................
    slough
    Ok, it is the best thing to do really as there are no additives in the disilled water , namely chlorine, salt and some others that over time could slowly corrode the water ways in the engine and even affect the head gasket, but having said that I also have a feeling that antifreeze would possibly neutralise these, I don't know for sure, anyhow I've always used Tap water myself and not had any issues from using it.
    Cheers Pete
  1. antifreeze
    By matts1185 in forum Engine & Drivetrain
    Last Post: 29th November 2012, 14:02
  2. Antifreeze
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 17:16
  3. Antifreeze
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 23:21
  4. AntiFreeze
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2011, 14:18
  5. Antifreeze
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 19:38
