Thread: 02 Vectra C 2.2 Dti- Brake Pedal Problem
    Nov 2007
    Ballygawley
    Unhappy 02 Vectra C 2.2 Dti- Brake Pedal Problem
    Hi Guys,
    Just after replacing the back brake pipes on my vectra (rusted) for MOT. Pretty sure back section off master cylinder was drained. New pipes on and brakes bleeded. When car switched off I have a great pedal but switch the car on and the pedal slowly falls to the floor. Brakes where perfect before this change. Anyone got a clue, we're standing around the car scratching our heads.
    Cheers All.
    6 Post(s)
    Its been mentioned on here before that with diesels you can get pedal creep - which is basically what you're getting. Surprised you weren't getting it before the work started though.
    http://www.vectra-c.com/forum/showthread.php?t=74759
    Nov 2007
    Ballygawley
    Cheers Big Dave,
    My pedal goes straight to the floor, we timed it at 14 seconds on the first press down after being pumped up switched off.
    Nov 2007
    Ballygawley
    Hi Guys, Any help would be greatly appreciated.
    Nov 2007
    Ballygawley
    Bump
    6 Post(s)
    Did you force any brake fluid back into the master cylinder? If you, there's a risk of flipping the rubber seals.
    Full Member Big Sig's Avatar
    Dave they are double sealed, but there is still a risk. maybe bleed them again?
    Nov 2007
    Ballygawley
    Smile
    Hi,
    Spoke to Stealers. They have a preesure bleeding system but don't use it. They bleed as normal, and what air they don't get out gravity does the rest. Oh yeah, my master cylinder is 100%. All vectras do this seemingly. Patience and love is the cure for everything. Cheers all
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. brake pedal problem
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 1st September 2012, 17:44
  4. Hello, my first thread ;) Vectra brake problem
    By Snod_donkey in forum Introduce yourself.
    Last Post: 2nd July 2010, 21:47
  5. brake pedal
    By barrie m in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 21:21
