Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: To De-cat or not
    Apr 2009
    Bourne
    Default To De-cat or not
    Hi There,
    I have just purchased a 2006 Vectra 1.9CDTi 150BHP with 125k on the clock and it isnít quite as quick as I thought it would be.
    I am thinking that with mileage the cat may have become clogged up with soot. Has anyone out they removed the cat or modified the catís internals to improve the exhaust flow?
    How will any cat modifications impact on the performance of an otherwise standard car?
    My only other planed modification in the short term will be a K&N panel filter.
    Thanks in advance.
    Paul
    Belfast
    I had a Magnex pipe that replaced the pre-cat on my 1.9-150 Astra. Did a good job, seriously reduced low end lag, made the turbo considerably more audible, but did increase reek on high revs.
    Chelmsford
    Personally, like many, I'm against de-cating... sports cat is the way forward if you want to do something to improve the bhp, but a new standard part will probably make a fairly big difference too. The current one is bound to be a bit gunked up.
    Regular Member sristeven1's Avatar
    wirral
    defo sport cat for me never would de cat a car at end of day more trouble then its worth
    Apr 2009
    Bourne
    Hi All sorry I have been away from the PC for the weekend.
    ZS how similar is the Astra engine to the Vectra? Did you have any problems, increased fuel consumption or any warning lights etc.?
    DNS and sristeven1 why wouldnít you de-cat? I have fitted de-cat pipes to all my previous diesel cars without problem, never had one this recent though hence my concerns and questions asked.
    What have people out there done and have they had problems or positive results?
    Has anybody got info where to buy de-cat pipes for reasonable money or have they just removed the innards from the current cat?
    Regards,
    Paul
    Regular Member steve0's Avatar
    UK
    Wouldnt decating effect the emmisions and in turn cause problems come MOT time.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    mine is decated and its much smoother and feels more lively at low revs, in a nut shell.....much better
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    so rich you then got rid of the cat then kept the centre box and the two back ones? plannin to sort my exhaust this month
    birmingham
    Engine : 3200
    Quote Originally Posted by aerodynamic18 View Post
    correct, there is no change in tone at all, its a much better drive m8
    Aug 2007
    Lisburn, N.Ireland
    any increase in smoke or anything? did you keep the cat just incase mot needs it? is yours chipped? when is yours due the mot
