Results 1 to 10 of 11
Thread: Battery Light Staying on
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Default Battery Light Staying on
    Hi everyone, i think i may know the answer to this problem but it could be something else.
    The battery light on my 1.9 cdti came on and stayed on whilst going to work this morning, i turned the car off and restarted it the light went out.
    But on the way home this evening the light came on again. So is the alternator knackered or is there some other prob????
    i rang my local parts place up and was quoted £160 +vat but then it gets tricky what amp one do you want matey? No idea was my reply and was told to have a look.
    Well i had a look i can not see nothing on it, but it looks like a complete nightmare to take off, i can not find a How 2, so is it a job that a lunatic like myself is able to do and which alternator do i order and the motor factor reckons its a next day item.
    Any help, words of wisdom gratefully received.
    Thanking you all in advance..
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Must be someone who can help????
    Admin plasma's Avatar
    On the Forum
    287 Post(s)
    Engine : 150
    Mileage : 74000
    not done one but lemme lookup and see how many spanners it is
    On the Forum
    287 Post(s)
    Engine : 150
    Mileage : 74000
    Doesnt appear to be too hard according to TIS, lemme see what Mr Haynes says as well, 3 spanners..
    Looks okish reading what its saying from both info sources. Drop the V belt undo a wiring harness and then alternator bolts then remove. Lemme know if your gonna tackle this. I'm busy saturday but can help sunday if your gonna do it then and your not working.
    btw, think the 1.9's are 100amp alternators
    edit, they do 3 types for the 1.9. Give me your reg via pm and I'll look it up for you.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Cheers matey, will let you know, i need to get one andwhat amp it is so i can get one.I was given 3 choices from the local parts shop.
    On the Forum
    287 Post(s)
    Engine : 150
    Mileage : 74000
    PM me your reg and i can look it up here..
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    The problem has been solved with a new alternator, before you say wheres the pics i forgot to take any, all i will say its a nightmare of a job, undoing the alternator was the easy part getting it out of the engine bay was a little bit harder, but its sorted now.
    Thanks for all the help (Glynn and Plasma)
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by plasma View Post
    there is 4 dean
    1. 100 amp reatils £291 + vat
    2. 120 amp £291 + vat
    3. 130 amp £320 + vat
    4. 140 amp £477 + vat exchange unit
    Quote Originally Posted by phil67 View Post
    your welcome phil
    Quote Originally Posted by glynn View Post
    there is 4 dean
    your welcome phil
    Out of interest, why the difference in amperage? .................
    Quote Originally Posted by Tadpole View Post
    i would of thought for heated seats, and all the other electical stuff that can be fitted
  1. Oil light staying on
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 22:31
  2. Indicatopr Light Staying On?????
    By lubo_tl in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2012, 21:27
  3. TC and ABS light staying on?
    By JonSRi150 in forum Engine & Drivetrain
    Last Post: 31st December 2009, 22:10
  4. steering light staying on but all ok
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 22nd January 2008, 18:55
  5. Battery light staying on
    By roukel01 in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2007, 08:17
vauxhall signum battery light stays on
vauxhall vectra battery light staying on
