Thread: Found fault code but stuck
    Regular Member vectra-c1000's Avatar
    in a veccy
    Default Found fault code but stuck
    Like above i have had the computer on my car and came up with these codes p0105 reads map/barometric pressure circuit.
    p1105 reads barometric sensor.
    Can anyone tell me what part i need or part numbers as i need my veccy back on the road haha
    Many thanks...
    in a veccy
    bump
    Surrey
    I have seen them on Ebay. Not sure why sensor it is. I take it you have checked the pipes for splits etc.
    in a veccy
    yes everthing looks fine to me but am no expert.
    in a veccy
    Bump.
    Full Member spennny's Avatar
    Blantyre
    Code P1105 gives you just too many chances. Would be good to know what was the exact fault code:
    P1105
    -07 Barometric Pressure Sensor Circuit High Input
    -03 Barometric Pressure Sensor Circuit Low Input
    -FA Barometric Pressure not plausible with Boost Pressure
    -1F Barometric Pressure Sensor Circuit Malfunction
    If the input is high, or low, then a wire problem is possibly.
    If the "Barometric Pressure not plausible with Boost Pressure" is the case, then it could be a plausibility problem with the boost pressure sensor.
    CHECK YOUR TURBO PIPES MATE - £10 ON IT ONE OF THEM HAS SPLIT
    Did you check the intercooler, or the turbo lines? How does the boost pressure looks like?
    Surrey
    My money is on a leak somewhere too that's why I said have you checked them.
    in a veccy
    Thanks for that i will get my friend to have a 2nd lok as i no nothing about cars. wish you lot where closer lol.
    Surrey
    I am no expert but just check every pipe is tight and doesn't have a split in it. Take the cover off and have a look.
    in a veccy
    Ok checked the pipes everything seems fine. The car is starting now but no revs at all just stays at 500 rpm. so what do you lot think i should buy to start with and where are they located or is there a pic of the 2.2 dti sri 52 plate.
    Thanks.
  1. finally found a solution to the P1112 fault code :-)
    By Casper85 in forum Engine & Drivetrain
    Last Post: 7th December 2012, 14:00
  2. stuck in limp mode p 1604 ecu code
    By christopher8079 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2012, 16:07
  3. Fault codes p0110 & p0105. EML on. Stuck in LHM
    By halster78 in forum Engine & Drivetrain
    Last Post: 7th May 2012, 16:02
  4. Found the fault code but what does it mean
    By Telboy in forum Vectra C / Signum Troubleshooting
    Last Post: 10th July 2011, 19:49
  5. New fault code found
    By V5LED in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2011, 17:26
