Results 1 to 10 of 14
Thread: Key fobs....UGH!!!
    Regular Member TonyR's Avatar
    Walthamstow, London
    Thumbs down Key fobs....UGH!!!
    I thought that I was being a sensible chap only having had my Vectra C for a few weeks and changed the batteries in the fobs......bad move
    One will work without any problem, the other will do diddley
    The red light will flash, however will not open thew car. Manually it will unlock the doors but not start the engine
    Help please???????
    TonyR
    Sounds like you need to resync the key with the car. You only get 30 secs or so to change the batteries before it loses it's 'pairing'. I can't recall the procedure off the top of my head, but it is in the owners manual. If you haven't got a manual let me know and I'll look in my manual (or somebody else may if they get there first)
    BTW welcome to the site
    HTH
    Walthamstow, London
    Duncan
    many thanks for the reply, I will start to use the grey matter and hopefully sort ythis pain in the a**e out.
    Good to be on the site, lots of info and assistance.
    TonyR
    Walthamstow, London
    Bad news, can't find anything in the manual regarding the replacement of the battery in the fob and possible results....Boo Hoo!!!!!
    I'm open to suggestions??
    TonyR
    Regular Member cpt slow's Avatar
    In a house
    To reprogramme, put the key in the ignition, turn until you get the dash lights, then press the fob buttons. If successful, the central locking will activate.
    Ashington, Northumberland
    As above, with ignition on, press lock button on fob once. Doors should all lock and immediately unlock. That's it, job done. Then try locking the car with the fob in the normal manner. HTH
    In a house
    Le us know if that solves your problem , it should work !
    Walthamstow, London
    Quote Originally Posted by caprimanuk
    Well guys.....
    I tried this system to re-prog the fob....no joy.
    Any other suggestions gratefully accepted.
    TonyR
    In a house
    Try taking out the battery , then replace it . Then try ignition on procedure .
    Walthamstow, London
    Tried it......not a peep. Now hacked off!!!!
    Boo Hoo
    TonyR
  1. fobs/keys
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2010, 13:25
  2. spare fobs
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 18:30
  3. Flip key fobs.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 08:31
  4. Key Fobs
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2007, 16:58
  5. Vectra Key Fobs
    By Manni2375 in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2006, 09:27
