Thread: 1.8 petrol problem
    glasgow
    Question 1.8 petrol problem
    when i start up in the morning and go a very short journey then turn off the engine the engine wont start it seems to be flooding as there is a strong smell of petrol under the bonnet eventually when it starts i get no response from the accelerator rac came out disconnected fuelpump cranked the engine over a few times the reconnected fuelpump it starts,this only happens in the morning and if i dont have the engine running more than at least 10 mins till normal running temp ,any ideas
    its a vectra 1.8 petrol on a 52 plate
    glasgow
    Quote Originally Posted by alexgrfc View Post
    Any ideas pleas
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    We had a vaguely similar problem with a Hyundai 1.6 16V and it was a faulty coolant temperature sensor (or something like that). The ECU gets wrong data from the sensor, so the fuel pump gives it more juice than needed which results in flooding.
    glasgow
    thanks m8 ill replace them and see if it helps any idea wich one it could be and how many are there on them?
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    I hav'nt herd of many problems with flooding engines in Vec's 9could be totally wrong on this). The ECU is pretty tight. I would say that there is a sensor going blink somewhere for it to have happended.
    Any fault codes (warning lights) come up on the dash???
    On second thoughs look at this thread from the resident Doctor of Veccy's!!!
    Click here!
  1. which parts of a 2.2 petrol direct duel exit exit will fit a 1.8 petrol?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 10:25
  2. Temp Problem - Petrol Engine
    By masch.tab in forum Engine & Drivetrain
    Last Post: 30th July 2009, 13:32
  3. Turbo problem on 2.0t petrol -03 estate
    By apk in forum Engine & Drivetrain
    Last Post: 29th June 2009, 19:36
  4. vectra c 2.2elegance petrol auto gearbox problem
    By popinoz in forum Engine & Drivetrain
    Last Post: 21st October 2008, 04:13
  5. 2.2 petrol starting problem
    By Johny Tango in forum Engine & Drivetrain
    Last Post: 30th December 2007, 19:17
