Thread: 2.2 dti 2003 rattle ????
    Regular Member paulf's Avatar
    county durham
    confused 2.2 dti 2003 rattle ????
    no real problems with the car fsh oil and filter changed air filter fuel filter all done car runs fine gears all smooth etc every now and again when reving past 3k theres a rattling noise coming from the engine only when at normal operating temp not when cold. Even when you rev the engine when stationary at normal operating temperature no rattle. Also no plumes of smoke hopefully no turbo trouble has anyone had a similar problem the car has 66k miles any help would be gratefully apreciated. Then I'l get it repaired A.S.A.P many thanks Paul great site keep up the good work.
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    is it something as simple as the bottom guard is loose?, mine started a similar noise
    hth
    Regular Member hmc_vectra's Avatar
    cupar fife
    county durham
    will have a look mate cheers anyone else had this type of problem ?
  1. vectra c 2003 brake rattle help ?
    By sparks in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2010, 23:08
  2. Rattle
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 19th November 2009, 22:29
  3. A rattle at 70
    By Jezza181 in forum Engine & Drivetrain
    Last Post: 25th March 2009, 08:02
  4. what IS this rattle?
    By trucker in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2006, 18:14
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
