Thread: Brake disc size?
    Regular Member joe2187's Avatar
    Chorley, Lancashire
    Default Brake disc size?
    I have a 1.9 SRi CDTi (150) 2004 (04 plate).
    What size brake discs front & rear will they be?
    As i've looked at ordering some & there are a couple of different sizes, dont want to order the wrong ones.
    Near Warrington
    Hi m8 have a look at brakes international in rochdale,check out the site i think it gives you the sizes.Hope this helps you my m8
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    This is from the 2004 product brochure
    Brakes
    Front ventilated disc brakes:
    All models (exc. 2.0i 16v Turbo/3.2i V6 24v/
    3.0CDTi V6 24v) – 285mm diameter.
    2.0i 16v Turbo – 302mm diameter.
    3.2i V6 24v/3.0CDTi V6 24v
    – 314mm diameter.
    Rear disc brakes:
    3.0CDTi V6 24v) – 278mm diameter (solid).
    2.0i 16v Turbo/3.2i V6 24v/3.0CDTi V6 24v
    – 292mm diameter (ventilated).
    Belfast
    Yup, 285 front and 278 back.
    Regular Member animal22's Avatar
    Cheshire
    some one told me the early gsi 3.2i was 302mm up front????
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes you are right early ones to begining of 04 were 302mm up front then they changed to 314mm
    PRESTON
    Trim : GSI
    As above, this is taken from an earlier brochure:
    Brakes
    1.8i 16v/2.0DTi 16v/2.2DTi 16v/2.2i 16v –
    285mm diameter.
    3.2i V6 24v – 302mm diameter.
    Rear disc brakes:
    278mm diameter.
    3.2i V6 24v – 292mm diameter.
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    so will the 2.0l LM edition brake calipers just bolt on to the standard caliper bolt holes on all the cars that have 285 fronts and 278 rears??
    really wana change the rubbish ones that are on at the moment. cheers, mick.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    All Vectra calipers fit onto the same hub it is the discs calipers and carriers that are different.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    so ifi was to change them to the 302's i would need new carriers, calipers, pads and disks?
    does anyone know how much the carriers and calipers are?
  1. Brake Disc Size
    By hodge725 in forum Suspension, Wheels & Brakes
    Last Post: 2nd November 2012, 17:41
  2. Standard brake disc size!?
    By rockafella8587 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2012, 19:33
  3. signum 2.2 direct brake disc size
    By jeffire in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 00:04
  4. Brake Disc Size (Apologies...)
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2010, 17:40
  5. Brake Disc Size...
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2008, 21:22
https:www.vectra-c.comforumshowthread.php76515-Brake-disc-size
vectra c brake front size
vauxhall vectra front brake size
vectra c brake disc size
vectra c 2.2 rear discs
vectra c 2.2dti brake disc size
vectra disc brakes size
vectra c v6 brake sizes
vectra c 1.9 cdti brake disc size
vectra c 3.2 v6 elite auto 2003 brake specvectra c sri brake disc sizevectra gsi 3.2 v6 front padsvectra c brake caliper sizeare sri calipers same vectra cvectra c 3.2 v6 elite auto brake discs and padsvauxhall vectra c gsi 3.2 brakesvectra c brake sizes2008 vectra 1.9 cdti 150 front brake padsvectra 2.2 sri 2003 which rear discsvectra c what size discs for calipervectra 2.0 turbo brake discs what size brake disc vecta 2.2 05vectra c disc size 2.2 insignia brake disc sizewould vectra 3.2 rear vented discs fit a 1.9 cdti 150
