Thread: Door controls problem
    manchester
    Default Door controls problem
    Hi i have a 3.2 elite 02. On the drivers side door controls, the button for the passenger winds is not working when trying to press down, it works going up. Also the door lock button wont work which is directly below that one.
    any ideas?
    Glasgow
    My passenger side switch unit does'nt work either
    Regular Member cameraman's Avatar
    Leicester
    I've got a set of door switches from a SRi facelift, don't think they have all the functions of the pre f/l though
    manchester
    Looks like a comman fault then.Anyone know how to remove them without taking the door card off?
    Quote Originally Posted by byebyeitsagsi View Post
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    My drivers side one doesn't always work when going down, have to press up first to get it to work!!
    Regular Member s0501291's Avatar
    Warrington
    Hi
    I fixed this problem on mine. Although on mine the switches did work but were very tempramental and you had to really press them. You can remove the switch by levering it out with a small flat bladed screwdriver. I removed mine and opened up the switch unit. I was able to clean the metal contacts on the circuitboard inside the swich unit and that fixed it. only took two minutes to remove and take apart
    Hope that helps
    Pete
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    as above, clean the contacs before paying out
    manchester
    Thankoo people will try it out soon as I get 5 mins
    Mileage : 000
    Yes as said above. A good clean should do the trick.
  1. For Sale: Blie/White Led Drivers Door Controls
    By Envy in forum Parts for sale
    Last Post: 7th January 2013, 20:15
  2. Replies: 31
    Last Post: 21st August 2012, 22:02
  3. Options for passenger door controls?
    By Envy in forum Styling
    Last Post: 19th June 2011, 22:08
  4. Door Controls
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2008, 15:03
  5. Problem with steering wheel controls....
    By Harry in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2007, 17:52
