Results 1 to 10 of 14
Thread: limp mode for no reason
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Default limp mode for no reason
    I have been driving to work today and the car was on cruise control down the motorway and then all of a sudden limp mode kicked in and cruise control was turned off i have no spanner light or any other dash light coming on. when i was stuck in traffic i turned the engine off and restarted the car and limp mode went away for about 10 miles and the came back again for what seems no reason the car is a 54 plate 2.0 DTi has anyone any ideas what it could be
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    All the usual suspect,s for this one mate .Check all your hoses for splits , check your vacuum hose connectors for perishing/cracks , clean your boost sensor or clean the egr valve , all very common faults with the dti engine, plenty of threads on here with how 2 s to show you what needs doing
    and still loving it
    Full Member Big Sig's Avatar
    You have limp mode but no fault light? It will be for a reason, do what Bob has suggested and if that doesn't help then its time to get the codes read
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    well took the car to VX and the following codes were sotred in the car but as it always goes got to the garage and everything was working fine so they could not tell me what was wrong. Can anyone tell me what these codes are and if they are a easy fix
    PO100
    PO105
    Regular Member vectra-c1000's Avatar
    in a veccy
    p0105 has came up on mine and it readsmap/barometric pressure circuit. hope it helps.
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Quote Originally Posted by vectra-c1000 View Post
    any idea what was done to fit it
    in a veccy
    Just waiting o a reply if anyone no,s but i miss driving it lol... if yu hear anythng you can let me know ta..
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    Could be the MAF and/or map sensor. Although it maybe something else giving those faults to trigger those codes.
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    is there any way i can test if these are causing the fault
    Engine : 2.0DTi
    Mileage : 73350
    Check your connectors on the actuattors for splits or being loose failing that have a look at mike 1986,s thread now on new posts for some guidance on checking the actuattors themselves.
    and still loving it
  1. Limp mode
    By irmscher-brett in forum Troubleshooting
    Last Post: 10th March 2013, 19:38
  2. EML Limp Mode. Help!!
    By Mission1979 in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 21:57
  3. Limp mode
    By irmscher-brett in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 15:12
  4. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
