Thread: abs warning light
    Nov 2007
    lancashire
    Default abs warning light
    can these be turned of or disabled some how. friend has one that wont go out, three hubs and lots of differant people looking at it hasnt helped at all.
    Has he had the fault code(s) read out to find out what has put the light on?
    May 2008
    Tyneside
    Think you will find that it is an MOT requirement for the light to work correctly.
    Nov 2007
    lancashire
    thats the problem mot is up now and cant seam to sort out light!!!.
    if it was the oil vectra b i would have pulled the bulb till i got it sorted but led's on these new'ens.
    he had it in another garage yesterday to get it sorted and there computer was down so no fault codes could be recovered.
    Full Member Big Sig's Avatar
    you shouldn't rally be able to pull the bulb as its supposed to come on and go out again. But thats up to the mot tester to spot!
    Unfortunately, getting the codes read is the only option. Personally after replacing 3 hubs and its still not fixed I would only be using someone with a tech 2.
    Nov 2007
    lancashire
    well hes getting it tec 2'd AGAIN tomorro so good luck to him!!!
    Quote Originally Posted by taxidriver50005 View Post
    Matters not whether it's a bulb or LED. The warning light is a testable item. If it doesn't follow a certain pattern then it's a fail.
    http://www.motuk.co.uk/manual_340.htm
  1. Warning Light
    By chrissy white85 in forum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
