Results 1 to 10 of 20
Thread: Fault Code
    Kent
    Default Fault Code
    I just found my scribble from the other day when the car went into limp home mode the code was:
    P0234
    Could someone be kind and have a look in their wee book as to what the code is, the mechanic told me something to do with boosting, car hasnt gone into limp home mode for a few days and I checked the pipes and found no splits. Car is going in just after easter but I'd rather try and find the fault then pay someone god know how much to find it.
    I think I listed all the fault codes in the tech section
    Kent
    ah ok I will take a look thanks
    Just have, couldn't find it? Guessing its been deleted
    Correction, here they all are
    http://www.vectra-c.com/forum/showthread.php?t=19442
    P0234 Engine Overboost Condition
    Could be the sensor or the actuator if yours is actually a turbo of some sort.
    Kent
    thanks mate, I did a search on P0234 and read quite a few posts where the ECU sofware required upgrading is this true?
    If so what is the current version and could I ring my loack dealer and find out what version Im running?
    It may help, but I would imagine they would need to plug the tech 2 in to find out. If its got a full vx history then it maybe running the latest software as my local one usually updates as a matter of course.
    Kent
    Something I could check maybe, I found this post:
    http://www.vectra-c.com/forum/showth...ighlight=P0234
    3rd pic down it shows 4 bolts to remove, is that the turbo, whats would I find in there?
    That looks like the "throttle body" not sure whats in there tbh on the dti. Sorry Tony. I think the turbo on the 2.0 and 2.2dti is down the back of the engine, under that round silver thing in the first pic.
    Kent
    ok thanks, the P0234 seems to be a common problem on the DTI I cleaned the EGR valve few weeks previous just hope its not related to that
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
