Thread: how can i replace a rear passenger door on vectra
    liverpool
    Exclamation how can i replace a rear passenger door on vectra
    Hi,
    i have damaged my rear passenger-side door, i have bought a new one same color second hand. but i know how to put it on but i will need to swap the glass over, and will the central locking just work if i just plug the electrics back on to the new door, the window is operated with a handle and not electric, i havnt yet started the work until i know i can do everything, if you could help with just the removal and replacement of the window that would be appreciated.
    thank you
    Chester
    Moved from How 2 section.
    Regular Member poves's Avatar
    lancashire
    The window will be a nightmare mate if you don't know how to swap it.
    There is a plastic clip in the bottom of the glass which splits in 2 pieces , then withdraw them from mecho and take glass out , you will have to unscrew the rear bar in the door to get the glass out , drop me a pm if you struggle.
    Smile
    Hi there, i did a damaged 2.2 sri a while ago where i had to change both passenger side doors.
    I got them in same colour which was a bit of luck, swapped them over, but after i had dumped the dented doors at the tip, the new doors would not open or the windows would not work.
    I had to go back to the tip and retrieve the old doors. I took the wiring looms out and put them in the new doors, and all was fine.
    With the CanBus sytems, the car knows if you change part of the wiring loom and will not let it become part of the existing system.
    If you re-use your wiring loom to fool the car that you are putting back on the same door, you should have no problems
    Feb 2007
    Glasgow
    Quote Originally Posted by asfy85 View Post
    No need to change the whole loom (unless it's damaged), just the door modules.
  1. Want to Replace Front Passenger Wing on Vectra C
    By vcurious in forum Bodywork & Interior
    Last Post: 3rd March 2011, 20:48
  2. Vectra 05 GSI, Rear passenger door won't open
    By bignew in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 15:29
  3. 17" sri alloys and passenger side rear door
    By jonny22 in forum Parts for sale
    Last Post: 4th October 2009, 17:19
  4. Rear windscreen smashed...cant open any passenger door...pls help
    By sudiptabd2002 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2008, 20:34
  5. No power to rear passenger door!
    By tommoturbo in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2007, 18:48
vectra c passenger door module
replacement vectra sri door
remove rear passenger window vectra c
