Results 1 to 10 of 11
Thread: bulb warning light
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Default bulb warning light
    i have a bulb warning light keep coming up on my dash abd then gowing off after a few miles i have checked all the lights and no bulb has gone does anyone know why it keeps coming on. also it does not matter if i have the lights on or off
    Quite a few threads on here m8 try the 'search' bulb about to go vectra has a good system hth .........
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    A loose bulb?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Will be a bulb blown and when it gets hot it refuses/welds back to filament best to change offending bulb
    Glasgow
    It will blow shortly, might be worth your while doing it just now before it goes.
    Regular Member PAULMAC77's Avatar
    warrington
    try looking at your brake lights, you may notice one side is actually lower than the other, this is because the vectra uses the side light bulb if one of the brake lights blows so u still have 2 working.. mine was like that, didnt notice it at 1st you just see 2 lights light up and carry on as normal..
    Full Member Big Sig's Avatar
    Regular Member darko2301's Avatar
    Croatia
    do you have bc? if you do, your cid/gid is supposed to precisely say which bulb is blown (e.g. Check rear left brake light)
    useful thing
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    Quote Originally Posted by darko2301 View Post
    useful thing
    what is BC?
    Regular Member badback's Avatar
    Runcorn
    I had the same problem, it turned out to be a loose side repeater bulb, a bit of wd40 sorted it. Check all bulbs are securely fitted. HPH.
  1. bulb warning light
    By woodze in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 12:24
  2. Bulb Warning Light...
    By Ross-SRi in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2011, 20:49
  3. Bulb warning light
    By corm in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2011, 19:03
  4. Bulb warning light
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 00:13
  5. bulb warning light
    By nufckev in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2008, 20:29
