Results 1 to 10 of 14
Thread: stripped my front suspension down today
    Regular Member solorider's Avatar
    swindon
    Default stripped my front suspension down today
    and i replaced both front springs and inner tie rods,and i have now fixed my suspension knocking.
    any of you know what i found what was causing the knocking,and it was not one of the parts i replaced?
    Jan 2006
    Dalriada
    Spill mate as i have suspention knocking...
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    a stone stuck somewhere ?????
    Midlands Mod Shop - NFFC.
    Admin plasma's Avatar
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    drop links?
    Belfast
    Woodpecker under the arches?
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Check you've built the legs up correctly - not sure if Vectras will knock but Cavs used to if you got things wrong
    swindon
    Quote Originally Posted by plasma View Post
    drop links?
    nope,they are ok
    Quote Originally Posted by JagRigger View Post
    i have cured the knocking,the car was knocking very badly,it would knock if you turn the steering to the left and straighten up,but not to the right,it would knock when you pulled off,and if you eased off and reapplied the power,and it would knock if you reversed into a space and braked.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    a bolt loose somewhere ??
    Sunny Dartmoor
    What was it????
    swindon
    Quote Originally Posted by AntSSSS View Post
    yes,the bolt that goes through the rear end of the front arm bush (rear bush) was loose,what is annoying this arm was changed a year a go by nationwide auto centre,the arm was a pattern arm from partco/unipart. (it was done before i bought the car)
  1. Suspension done today,
    By ScotsDragon in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2012, 18:46
  2. Today I stripped....
    By wingz123 in forum General Chat
    Last Post: 26th April 2011, 11:11
  3. Ordered my suspension today
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2011, 20:46
  4. fitted sri Suspension today
    By Edd in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 21:10
  5. sorted out my noisy suspension today.
    By kev bux in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2007, 18:48
