Thread: 40/45mm Springs for Signum
    Regular Member andy13's Avatar
    Default 40/45mm Springs for Signum
    Does anyone know of anywhere that does 40 or 45mm lowering springs for a signum 1.9cdti? I can only seem to find 30/30 or 35/25.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    pi are your best bet m8
    Regular Member Robbie69's Avatar
    THey don't seem to do them any lower for the Signum!
    derbyshire
    they say you need to use shortned shock absorbers?? do you??
    Luxembourg
    Well, the signum is a vectra c, so all should be he same.
    The difference might be that the signum usually has softer and longer shocks which may not damp enough for lowering springs. So when the springs are too short, you might end up bottoming out the shocks or hitting every speedbump. HTH
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    I had Pi 45mm with B4's on my siggy and to be honest it was too low, the 30mm eibachs with either B4's or B6's are the way to go for handling HTH.
  1. Pi 45mm springs
    By Fig-sri in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2010, 11:08
  2. SuperSport -45mm springs
    By damian s in forum Parts for sale
    Last Post: 9th December 2009, 23:25
  3. Which 45mm lowering springs?
    By Rik N.I. in forum Handling & Braking
    Last Post: 26th April 2008, 19:46
  4. -45mm pi springs
    By hagga in forum Handling & Braking
    Last Post: 7th July 2007, 00:17
