Results 1 to 9 of 9
Thread: 03 vectra auto gearbox problems
Hybrid View
    Feb 2009
    thorne, doncaster
    confused 03 vectra auto gearbox problems
    Can anyone offer any help or advice please?
    Ive just purchased a 03 vectra 2.2 with a dead gearbox, im considering switching it to a manual transmission but was wondering what extra work it would involve.
    Would there need to be any software reprogramming or extensive rewiring carried out?
    Has anyone done this before?
    Any advice would be greatly appreciated..
    Cheers..
    Glasgow
    The swap over would cost a fortune a lot more than what the cars value is, have you tried getting a re-con box or even getting your own reconditioned?
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    where did you buy it from ?
    Feb 2009
    thorne, doncaster
    hi, ive found a local breakers yard with all mechanical parts to switch it to a manual for £300, the cheapest i can get the original box reconditioned locally is £1400 +vat, and ive found a couple of breakers with auto gearbox's for around £1000+..
    obviously the much cheaper route would be to switch but can it be done?
    i bought the car locally for £700..
    Regular Member poves's Avatar
    Dec 2007
    lancashire
    If you go the conversion way , your dash will light up like a christmas tree with all the autobox ecu sensors not registering.
    My advice would be consider breaking the car , then buy a manual .
    This forum is full of horror stories regarding the autobox , I had one as well - not any more though
    Jun 2011
    bolton
    Hi, I Hav a 2.2auto too, its done 97k but theres no fault with gearbox yet, touch wood. Can any1 tel me hw i can keep it from knackering up on me as the whole car is sweet, Thanks
    Regular Member Jezzy's Avatar
    May 2009
    S.E
    Get the gearbox oil changed, and ignore any garage that says "it's not mentioned in the service book, so doesn't need doing".
    Bristol
    Default auto to manual
    Hi if you fit the manual box get someone with an uptodat snapon kit or op-com software and reset the ecu that will clear all info and then reset it as manual .
    Feb 2009
    West Sussex
    Quote Originally Posted by Jezzy View Post
    My auto box has done 84k, still fine and I had the auto fliud changed last year. Well worth getting fresh fluid, not that expensive.
  1. Auto gearbox problems
    By Denn in forum Engine & Drivetrain
    Last Post: 15th April 2012, 22:23
  2. problems with auto gearbox
    By xxxvecxxx in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2012, 19:29
  3. af23 auto gearbox problems
    By andyadams in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2010, 21:24
  4. please help!!! vectra 2.0 dti ls, gearbox problems
    By tazzy in forum Engine & Drivetrain
    Last Post: 11th January 2009, 00:17
  5. AF33 auto gearbox problems
    By Jay-C in forum Engine & Drivetrain
    Last Post: 11th April 2007, 10:37
vectra automatic gearbox problem reset
vectra c auto gearbox problems
vauxhall vectra automatic gearbox faults
vectra automatic gearbox problem reset site:www.vectra-c.com
vectra c gearbox ecu reset
vectra automatic gearbox problem reset af33
af33 5 transmission problems
vectra c auto gearbox using it in manual
vectra c automatic transmission problems
https:www.vectra-c.comforumshowthread.php76204-03-vectra-auto-gearbox-problems
Tags for this Thread
