Results 1 to 10 of 22
Thread: wishbone next???
    Regular Member signum03's Avatar
    worthing
    confused wishbone next???
    hi all, today i changed the o/s front arb bush and drop link succesfully hoping it would cure the problem......but it didnt! the problem i have is when going over speed bumps or uneven roads there is a noise from the front o/s which seems to be a grinding,metal on metal noise (difficult to describe!) so next i think i will change the wishbone, vx want £180+vat but after looking on ebay can get one for around £60, is there much differnce in aftermarket quality? the next question is if i change the wishbone abd and the noise is still there what next. by the way took the car to vx and the said there was no fault! maybe if they took it for a road test rather than sticking it on a ramp may help. all advice apprciated.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like it could be the spring rubbing in the cup on the shock, have you got the sleeve on the spring where it sits on the shock
    worthing
    when wheel was off today had a good look at the spring no rust or cracks, did not notice a sleeve, changed a few springs over the years others never had a sleeve???
    worthing
    do you mean the lower cup?
    Quote Originally Posted by signum03 View Post
    yes m8, have you had the springs changed before??
    jack it back up to see if there is a sleeve on the end of the bottom coil of the spring, if not get 2 from the dealers and fit them to see if that works, as it will be alot cheaper
    worthing
    have all vectra/signum c's got these then?
    mine did on the oe springs, but i forgot to fit them straight onto my lowered springs, then i was getting a slight nosie, i i fitted them on and its stoped
    worthing
    thanks i will do that at the weekend , not sure if it will fix it though noise seems/feels to be just forward of driver foot well? have also checked exhaust and its fine?????
    if you can feel it by the foot well it could be the rear wish bone mountwhich you can get on there own
    worthing
    do you mean the front o/s wishbone where the noise is, or the rear wishbone i.e back of car(rear wheel)?
  1. Front Wishbone
    By faz3270 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2012, 23:16
  2. Help needed for a wishbone
    By mickyh7 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 19:28
  3. Wishbone torque
    By Alerxt in forum Suspension, Wheels & Brakes
    Last Post: 21st September 2011, 19:56
  4. Little Thing On Wishbone
    By Skinner in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2010, 00:13
  5. Front Wishbone
    By dov21 in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2008, 21:10
