can any one help carnt seem to get radio out of my vectra and have brought the removing tool any ideas anyone???????????????
Mine was easy (ccr2006), remove 4 grub screws, insert removal tool as far as it will go and pull the stereo out, job done!!
have tryed that and it just wont come out?
pull the storage tray out , then slide the heater controls out and disconnect plug (really easy to get out)
Then pop the plastic strip off that runs accross the passenger side of dash , then remove the torx screws from the bottom of the multi function display then slide it outta the way.
This should give you room to get at tear of stereo to push or pry , they can be stiff.
Should only take 5 mins to strip the above bits .
mine was a pig to get out. push your keys in until the click then push both outwards whilst pulling out.
