Thread: Swirl valve actuator--Connection Bar
    member of the smoke patrol 230bhp+
    Default Swirl valve actuator--Connection Bar
    when you replace the inlet manafold and use the same motor do you need to get a modded Connection Bar as as my swirl flap seam to be open on normal running
    ie it's like the littel black plastic bar brtween the motor and inlet is to long so is opening the swirl flaps far far to soon
    hope somebody can help on this one
    Belfast
    I thought you needed to get a new motor, as each motor "learns" it's position from the manifold, and if you change the manifold the motor won't be in the correct alignment. At least that's what the Pierberg document says...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by _ZS_ View Post
    Thats spot on...
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Definatley - you must change the actuator motor as it does learn its alignment etc. This is documented by VX and by the manufacturer of the Inlets.
    Norfolk
    Engine : 1.9 16v 150
    Year : 54
    Mileage : 140000
    Sorry to post on an old thread but if you are using a second hand inlet manifold, can you use the motor off that car to, keeping them together. I was thinking the motor would have learned that manifold and I could put them both on another car together.
    Middlesex
    Trim : SRI
    Mileage : 100k
    in therory yes - if you have the actuator that was on the car with the inlet then you will be ok.
    Ill be honest tho - if your going to do the job of changing the inlet - I wouldnt use a second hand one.
    A
  1. Swirl valve actuator bar
    By Big Si in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 08:34
  2. Connection between swirl valve and the actuator
    By genesisfm in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2011, 19:58
  3. swirl valve actuator
    By wirrallad in forum Engine & Drivetrain
    Last Post: 4th August 2009, 19:54
  4. Swirl valve actuator
    By Tigger in forum Engine & Drivetrain
    Last Post: 26th July 2009, 22:26
  5. Swirl valve actuator
    By oxenburger in forum Engine & Drivetrain
    Last Post: 24th March 2009, 19:17
