Thread: squeeky brakes help!!!!!!!!!
    Nov 2005
    newcastle upon tyne
    Default squeeky brakes help!!!!!!!!!
    hi all i changed front pads this morning & greased everything that you should the annoying squeek is still there it seems more noticable when i turn please help someone
    Nicking Ya Dinner.
    Is it under braking or all the time Steve, also how many miles has your car done?
    Nicking Ya Dinner.
    The annoying squeak could be a warped disc, are they worn? or have you levered pads back using the disc as a leverage point?
    Regular Member cyb's Avatar
    Did you change the front pads for OE ones or a cheaper version?
    Apr 2006
    lanarkshire
    I had a similar problem a few years ago on a primera turned out that disc had a small lip which was touching the pads when they had released. Filed off lip and noise disappeared. Hope this helps
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    i had a prob like that when i had my omega they squeeked when i took my foot of brake the cause was the pads expanding with the heat i got the grinder out and ground the edge of the disc's to a curve.
    i worked a treat.
    Nov 2005
    newcastle upon tyne
    the discs have got a lip on the edge it could be that whats the best way to get rid
    Nicking Ya Dinner.
    Quote Originally Posted by stevietiger
    replace discs
    I think Yorkie means he chamfered the edge from the pads so the edge no longer met the groove lip of the disc.
    Before you replace anything though, try to pinpoint which wheel its coming from, then jack the car up and spin the disc, see if it's out of true or the pad surface is rubbing the lip around the disc, if you've done more than 50k they will need replacing anyway, maybe not for an MOT, but for max effectiveness when stopping.
    Nov 2005
    newcastle upon tyne
    brakes sorted filed lip of disc & squeek has gone
    Nicking Ya Dinner.
    Which one was it Steve?
  1. Squeeky Brakes
    By Collis in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 18:17
  2. Squeeky Brakes
    By Griff72 in forum Suspension, Wheels & Brakes
    Last Post: 29th June 2010, 18:39
  3. Squeeky steering
    By al21784 in forum Suspension, Wheels & Brakes
    Last Post: 6th May 2009, 17:45
  4. Squeeky rear brakes, OVERHEATING too
    By hibbsy18 in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2009, 01:37
  5. squeeky brakes & wiper probs
    By stevietiger in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2006, 07:23
