Thread: White/Blue smoke on start up
    Regular Member jsr645's Avatar
    Northants
    Default White/Blue smoke on start up
    My vec has started smoking when you start the engine - typically when its been standing for a good few hours, not on every start, only when the car has been sitting for a while, like overnight.
    I wait everytime for the glowplug light to go out but when it starts there is a plume of bluish white smoke that comes out the exhaust for a few seconds then it clears. Starting is fine and engine doesn't seem lumpy.
    Its a 08 reg and just seems wrong. It has only just developed in the last week really.
    The smoke smells like diesel fumes - not like diesel or anything in particular, just typical diesel emissions.
    Any ideas? Maybe needs to go to stealers when I get some time. I'm worried it may be the early sign of lots of problems!! its only done 11k and although I tend to be unlucky with cars, I am extremely paranoid that my car has developed a serious problem when anything happens!
    Regular Member sidturbo's Avatar
    burnley
    i had a zafira with the same engine, that did the same every morning and never had a problem with it, seems pretty normal for a diesel engine.
    Nov 2007
    lancashire
    check your oil level, mine did this when over topped up, also are you on fully or semi syenthetic oil. when i bought my car it did it every time i started from cold, done a oil change with fully syenthetic oil and all is fine now!!!!
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Mines the same once its started its fine tho
    Regular Member DARREN R's Avatar
    Jan 2008
    WASHINGTON
    Vehicle : vectra
    Trim : sri xp
    Engine : z19dth
    Mileage : 93000
    mine does this as well never had any probs with it though ?
    Northants
    It just seems wrong for a year old car!! Well, its with the stealers tonight and tomorrow to check it out.
    Not sure about what oil is in it - didn't do it for 3 weeks then suddenly started doing it when starting. It briefly stopped after re-fuelling with a new tank of diesel, but started again today to booked into Vauxhall. I started to think it was the last tank of diesel (from tesco) but who knows - will find out tomorrow hopefully.
    Also, it seems to run ever so slightly rough when first starting, but otherwise is fine?
    I wondered if it was maybe fuel seeping through the injector and not buring properly when starting? I noticed it seems a common problem with the cdti with problems with injector 3 - could this be related?
    I brought a newer car hoping to avoid these problems! ARGH
    Regular Member dean_walsh2001's Avatar
    swansea
    mine does the same too
    Bristol
    My2.2 dti omega does it and my Vectra V6cdti this is caused by a small amount of air in the systen just a little leak somewhere nothing to worry about, once started its gone. Follow a passat or a ford when the put there foot down, loads black smoke. You won't find that following a VX. Whats better a little puff of blue or loads of black
    West Midlands
    JSR, any news from the Vauxhall garage on the smokey start up? Mine is the same, same age car and started about 3 weeks after i bought it too (Feb 09). Its been in to Vauxhall who keep saying theres nothing wrong with it, but ive had diesels before and they have never done it. I get the feeling they're trying to avoid some expensive warranty work.
  1. Replies: 53
    Last Post: 16th November 2012, 22:42
  2. Car starting on ez-start then on its own and white smoke.
    By Stoo2k in forum Engine & Drivetrain
    Last Post: 22nd May 2012, 19:07
  3. white smoke wont start
    By donny dave in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2011, 19:27
  4. white smoke on start up
    By m1ke823146 in forum Engine & Drivetrain
    Last Post: 5th April 2010, 23:31
  5. White Smoke - Cold start
    By DG01 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 21:12
why is there white smoke coming from my vectra c when i start it
