Results 1 to 10 of 11
Thread: Estate - want to install parking sensors in rear BUMPER
    Regular Member FinnRolo's Avatar
    Dublin, Ireland
    Default Estate - want to install parking sensors in rear BUMPER
    As per the thread title, I wish to install parking sensors in the rear bumper of my Vectra estate. However, in every thread I have found, people seem to have only installed them in the grey plastic "valance" thing below the bumper.
    Has anyone actually installed parking sensors in the bumper of an estate?
    If so, how big a job is it, and can you offer any advice to someone who has not attempted such a job before?
    Thanks in advance.
    Dublin, Ireland
    Anyone?
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I think the Estate and Signum share the same (or have a very similar rear bumper), It might help you out if you do a search on here for fitting rear sensors on a signum..
    Northampton, UK
    I bought a set on ebay (See the how to for Front Parking sensors) they are small enough to fit between the bumper bar and the bumper on the Signum.
    BUT... Just to make sure you do have room, I used some Play Doe, rolled it into a ball, pushed it on to where the sensors were marked on the bumper and re-fitted the bumper. Gave it a push around etc, then took it off again. I then measured the size of the lump of play doe to the size of the sensors to make sure I had clearence.
    HTH
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    There should be marks for holes on the rear bumper for drilling...4 in all.
    Regular Member Jeff Lynne's Avatar
    England
    Vec estate - very easy to fit in the rubber trim below bumper, did mine in hour or two, and purchased off ebay for £20
    there is a how to somewhre ...
    Dublin, Ireland
    Quote Originally Posted by Jeff Lynne View Post
    I've dug up quite a few posts on installing the sensors in the valance below the bumper. However, I would prefer to have them in the bumper itself.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes but there are no markings in the bumper itself on the estate, as its ment to be in the lower valance on the estate.
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Had to put mine in the rear valance as there wasn't enough room between the bumper and the crash bar. Took about hour and a half. I'll post a pic later.
    Devon
    Default Parking sensor not too low when installed in valance (estate)?
    Quote Originally Posted by kenp View Post
    I've seen several posts saying the sensors need to be 50 cm high. The valance is much lower than that. Can someone assure me (that is, someone who installed it in the valance) that the height is OK?
    Also, are the drill marks on the valance too?
    Thanks!
  1. Fitting aftermarket parking sensors to XP 'd rear bumper
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2012, 22:45
  2. estate rear parking sensors
    By Ryanlfc in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2012, 20:34
  3. Estate Rear Bumper Removal And Parking Sensors
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2007, 16:46
