Thread: Smaller tyres
    Regular Member GoldenWonder's Avatar
    Durham
    Default Smaller tyres
    Can I put 205/55/16 tyres on my 2004 1.9 CDTi (120)?
    It currently has 215/55/16 on its steel wheels and I can almost replace all 4 with the smaller tyres for the price of 2 215's!
    Obviously I'd have to do all 4 in one go (for the first time) but would this cause any problems?
    There seems to be less choice for the 215's than the 205s so the 205s are quite a bit cheaper.
    Newcastle under Lyme
    http://www.etyres.co.uk/tyre-size-calculator.htm
    They should be ok as the diameter varience is minimal. It will mean that the diameter is different and therefore if the speedo says you are doing 30 you could be doing marginally more or less
    Durham
    Cheers, handy little calculator that. Recommends no more than 2.5% difference and mine comes in at 1.71%!
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    ive got a set of winter 16" alloys with 205/55's on the front and 225/55's on the back, no problems, doesnt look alot different either.
    so you could do them in pairs.
  1. Would i be mad to downsize from 19" vxr rims to a smaller rim?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2013, 12:36
  2. Is the signum fuel tank smaller than vectra?
    Last Post: 4th February 2011, 02:27
  3. Which smaller car (172 or St170)
    By Gregg in forum The 'Off Topic' room
    Last Post: 15th April 2010, 19:02
  4. Should the Spacesaver wheel be 2" smaller
    By 67688c in forum Insignia car chat
    Last Post: 21st June 2009, 21:13
  5. Smaller Karcher PW & Foam Lances ?
    By Led in forum Detailing and Car Care Discussion
    Last Post: 21st June 2008, 23:00
