Thread: P1112 swirl valve
    Surrey
    Default P1112 swirl valve
    Since cleaning out my EGR and intake I keep getting a P1112 fault come up along with the emissions light on my 2.2i direct. Can you clean these?
    Attachment 18446
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    Retracting what i said, thought it was a Diesel lol.
    Surrey
    No not the dirty stuff.
    norn iron
    sorry for butting in mate but how did you clean the egr on your direct as i believe it is watercooled and not straight forward to do?
    Surrey
    It is water cooled but you don't get that much coolant leakage. I'm no mechanic and I can do it.
    norn iron
    nice one, did you find it needed done or were you doing it for the sake of it? any more info on this would be appriciated as i fancy doing this myself
    Surrey
    I did the air intake and thought I would do the EGR. I changed the plugs as well and it went very well afterwards.
    I will have a go at the intake this weekend but think the swirl problem may be expensive.
    Oct 2007
    estonia
    at first try the newest software to engine ecu. if this does not cure P1112 then you may try to clean (somehow) the swirl valve outer joints below intake manifold but probalby new valves (93192896)will help you. the swirls on Z22YH intake manifold can be replaced separately (not with intake manifold likke on Z19DTH). cost you ~200 EUR.
    Surrey
    New software, what does that change?
    Less that what I thought it would cost.
    Regular Member VeCeZ22YH's Avatar
    Jun 2011
    Bratislava
    Engine : petrol 2.2 i 155 PS
    Quote Originally Posted by steve1975l View Post
    anybody? how to flash the ecu? just via tech2 ? DTC set:
    P1112 - Swirl Flap Stuck
    (61) - Not present
    thanks
  1. swirl valve rod
    By pha-q2 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th November 2012, 17:36
  2. Hi CO and Swirl flap code P1112
    By silflex9 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 11:44
  3. Egr valve, swirl valve problems etc..
  4. P1112 Swirl flaps
    By patc in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 22:23
  5. Swirl valve
    By jacko52 in forum Engine & Drivetrain
    Last Post: 16th January 2010, 12:19
