Results 1 to 9 of 9
Thread: Lift or drop engine out?
    Oct 2007
    Shropshire
    Default Lift or drop engine out?
    I'm going to be changing the engine over on my 1.8vvt. Does anyone know if there is enough room to lift the engine out the bonnet or do you have to drop the subframe? I'm thinking that if you can lift it out, I will do it myself, but if you have to drop the subframe I will pay to have them swapped.
    Any input will be appreciatted.
    Bristol
    The best and quickest is out the bottom with subframe.
    Feb 2009
    Stockton on Tees
    Ya can lift it out but remove the gas struts and the bonnet lifts vertical which makes it easier. ;-) Or remove bonnet. Its not a big lump and the engine bay is massive. Try removing a 2.0 16v engine from an old Clio!!!! Its easier to take the car to bits around the engine!!! The post above is easier but if doing it at home out the top is DIY friendlier
    Wales, UK
    Not too well up on removing the unit from these cars, but interested as to what is going in its place ?
    Oct 2007
    Shropshire
    another 1.8 i'm afraid, its failing, oil pump i think.
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    imo 1.8 would be out the top
    Lots of room so guess should come out easy
    Regular Member gromit's Avatar
    Cumbernauld
    Out of the top. Took my 3.2 V6 out the top and didn't even have to remove the bonnet. It was easier to refit with the bonnet removed so you might as well remove bonnet before you take the engine out.
    Oct 2007
    Shropshire
    Thanks for the advice guys, I'll let you know how I get on!
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Took a 2.0 dti out 8 weeks ago. Wheels off drive shafts out. Take as many of the parts off you can for ease I.E Starter manifold, and lift out.
    Easy ISH!
  1. 1.8 Petrol Revs Drop Engine Cuts Out
    By vads in forum Engine & Drivetrain
    Last Post: 17th April 2012, 08:23
  2. Pre-face Lift & Face Lift Auto dimmin Rear View Mirrors
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2011, 16:25
  3. Replies: 3
    Last Post: 6th July 2009, 11:04
  4. 2.2DTI - Revs drop and engine cuts out
    By altheman2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2008, 20:55
  5. 2.2 sri 2.2 elite pre face lift engine
    By keeton in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 16:42
vectra c lifting engine from top
can you lift vectra c engine out instead of dropping it
