Results 1 to 10 of 19
Thread: hesitation when cold 3.0 v6
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    Default hesitation when cold 3.0 v6
    thought the cause of this might have been dirty fuel ,s got some millars to give it a flush and fitted a new fuel filter.
    i only appears when you put the boot down and once the car has warmed up there seams to be no problem ,i recently fitted a K&N element filter could this be causing the problem with the car being cold???
    or could it be a MAF problem
    anybody any ideas?? or any possible remedys
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I've never heard of MAF failure on the 3.0CDTi or any Isuzu engine.
    Since this Isuzu crap is exocita it could be a dodgy EGR, boost sensor, injectors, fuel pump, etc. You never know.....
    I'm just being extremly negative about this engine right now since it's giving me sleepless nights!
    I would, 1st of all, check the EGR valve.
    Full Member Big Sig's Avatar
    Quote Originally Posted by Celes View Post
    Just be happy its not a 1.9 150
    Oct 2007
    Back in Belfast!!!!
    what do i need to do with the egr ,or is that a dealers job??
    The egr only opens when the engine is under load, more than 30% throttle. Its not an easy job on the V6 but if you remove the plastic engine cover, there is a metal ridged pipe on the left hand side that goes to the egr. Remove that and you can see inside the egr
    Oct 2007
    Back in Belfast!!!!
    i have seen that silver pipe will have a look tomorrow cheers guys.
    Oct 2007
    Back in Belfast!!!!
    if it was the ERG would the problem not be there all the time not just when the car is cold.
    the other thing is the car has NEVER had a problem starting this hesitation is only happening when the car is cold and seams worse when it is very cold in the mornings.
    Oct 2007
    Back in Belfast!!!!
    well folks it turns out that it was the air flow meter(MAF) managed to get one sorted through a few mates (wink,wink nudge,nudge) for the right money and all is A OK again.
    and just to add i would say to anybody washing there car to be carefull when using jet hoses etc not to spray it in through the grill because thinking back this is when my problems started,and i beleive some water got sprayed into the MAF and fooked it up.
    Regular Member jonesy_ni's Avatar
    Co Antrim
    Quote Originally Posted by BIG NEIL View Post
    Thats what i thought it would be.
    Glad you got it sorted
    Oct 2007
    Back in Belfast!!!!
    Quote Originally Posted by jonesy_ni View Post
    cheers jonesy i'm glad it wasn't anything a bit more expensivei was thinking if it wasn't MAF it might have been fuel pump
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. Hesitation please help??
    By sowter28 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 17:43
  4. Hesitation
    By Deadman in forum Engine & Drivetrain
    Last Post: 5th July 2008, 18:40
  5. hesitation
    By pogo in forum Engine & Drivetrain
    Last Post: 26th March 2006, 21:06
