Thread: headlights stay on when switched off
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Unhappy headlights stay on when switched off
    Hi guy's, yesterday i started the vectra at lunch time and the bulb out symbol light up for about 30 secs and went out again so i thought nothing of it. When i drove home it was daylight, so i didn't have the headlights on at all. When i went out to go to work this morning i noticed the dipped headlights and side lights were on. So i presumed i had bumped the switch getting out the car last night, but when i got in the switch was off anyway, and because of that the battery had gone flat. Luckily i was able to borrow the girlfriends car to get to work. Any idea's whats gone wrong
    Steve
    Jun 2007
    Black Country
    Quote Originally Posted by woody in shetland View Post
    Steve
    2 ideas spring to mind
    1st. Bulb had blown and is shorting out, check and replace bad bulb as required
    2nd. Dim/Dip relay fault, was very common on Volvos in the late 80s
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Thanks Guyver1, i'll reconnect the battery and check for any blown bulbs.
    Jun 2007
    Black Country
    if you say you had a bulb failure warning come on previous, thats your first port of call mate
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Reconnected battery and all bulbs seem to work fine. I will fully charge the battery and see what happens over the next couple of days.
    Thanks for your advice Guyver1.
    Cheers Steve
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Hi guy's, i charged the battery and have been using the car as normal. I thought all was well as the lights have not come on themselves since, until today. Drove to work, parked up. went to go home at 6 and the lights were on again. Luckily no flat battery THIS time. Any more ideas as to whats going on.Cheers Steve
    Surrey
    I take it you don't have auto lights?
    Have you changed bulbs recently?
    Have you changed the switch?
    Have you unplugged the connection on the switch and on each bulb to look for bad wiring possible short and then re-connected?
    It's very strange for them to stay on dipped with ignition off. I found moving the indicator up and down while parked up whilst refitting the dash turned DRL on somehow, my post is around somewhere but can't find it. I had a new CIM fitted under warranty when my interior lights and radio were playing up. I hope the CIM doesn't do the ignition logic too.
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Hi Steve, no i don't have auto lights, or should i say, i seem to at the moment .
    Sorry but what does DRL and CIM stand for?
    I haven't changed any bulbs or the switch. I think i'll try having a look at some connections. Someone suggested checking the connections in the rear lights because of the canbus set up if it gets damp it can wreak all sorts of havoc.
    I'll keep you posted on my findings.
    Steve
    Last edited by woody in shetland; 1st April 2009 at 18:58. Reason: Adding a question
  1. help lights are still on when switched off
    By scania666 in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2012, 10:48
  2. We still getting switched off tonight?
    By Mark Evison in forum The 'Off Topic' room
    Last Post: 10th February 2012, 20:55
  3. Fiancée has switched for the better
    By george1987 in forum Non Vectra C/Signum Album
    Last Post: 11th April 2011, 21:37
  4. New switched fitted in
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2011, 22:57
  5. Vibration when air con switched on
    By marky2027 in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2007, 22:07
vectra c headlights staying on
Vectra c headlights stuck on
vauxhall vectra c headlights always on
headlight stays on with dead battery in insignia
vauxhall vectra dipped lights stay on
insignia headlights always on
