Thread: Ecu problems
    Kingston Upon Hull
    Default Ecu problems
    Hi some of you may remember a mate of mine is having problems with his 2l dti 04 vectra .
    the engine will not rev past 2500rpm
    He has had it to a auto electrishion today and they say its the ecu that is stopping the fuel pump from letting enough fuel to the pump / engine
    Can this be wright ? and a new ecu is going to be £1500
    Is there a way around this problem with out a new pump
    Thankyou
    Jacko
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    has the car had any work on the pump as where the multi plugs go in the pins can bend over and not make a contact.seen it twice before.
    Regular Member mattolly86's Avatar
    oxfordshire
    if i were you id take it somewhere else, if an ecu is just doing that its very strange sounds more like a sensor problem i know if the airflow sensor is unpluged it also wont rev past 2500rpm but 1500quid on one persons opinion is a lot and i personally would go to vauxhall to change an ecu and im a hgv mechanic!
    Kingston Upon Hull
    Hi the only things are egr valve and a new air mas sencer
    oxfordshire
    id still want a second opinon mate
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
