Results 1 to 10 of 13
Thread: Engine Mounts??
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default Engine Mounts??
    Theres a loud clucking coming from my engine bay and the gear stick jolts when i tickle the revs in low gear also when i back off power too.
    Further more my rad pegs have snapped which i presume is down to this.
    Is there a common engine mount that its likely to be and is this a hard job to rectify what would the cost be if a garage did this.
    Thanks people
    #bump please
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    One at the frt of the engine below the rads would be the easy ones to check.
    is it likely to be obvious as in perished or do they just weaken?
    May 2008
    Bucks
    Quote Originally Posted by craigbarlow18 View Post
    Both lol
    Might not be that obvious to look at untill its under load
    So you can either use a bar to check for play, or if you're a nutta stand in front whilst you let your bestest friend dump the clutch
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    also check to see if the bolt has fallen out!! Had one where i took the underbelly tray off the bolt was laying there! and the one above it was loose too..
    With the rads, you can get a bottom peg repair kit for it so you dont need a new rad
    nice one cheers folks, worrying i suspect the bolts option as it just started recently
    anyone know the price to have this fixed
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    price is to jack the car up, remove the tray and get yer head under there and have a look lol!
    ok i asked for that, lol, i mean if its broke, i dont feel like takeling it, i did a engine mount on a cvh years ago and it was a pain in the butt
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    I'm around on sunday if you want to pop down and I'll have a look for ya.
  1. Engine Mounts...
    By spoons in forum Engine & Drivetrain
    Last Post: 15th September 2011, 18:25
  2. 3.2 engine mounts
    By hankthetrucker in forum Engine & Drivetrain
    Last Post: 14th July 2011, 22:04
  3. Engine mounts
    By chrisvectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2011, 18:05
  4. engine mounts
    By leesri in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2010, 20:45
